Troubleshooting CUCM
techguy
Level 4
Level 4
Can anyone tell me whats the difference between Cisco Unified Serviceability and Cisco Unified RTMT. Which tool is most beneficial in order to troubleshoot the voice.
Leonardo Santana
Hello
Allows CUCM administrators to control feature and configure alarms and trace information, and so on....
RTMT
RTMT displays performance information for CUC, CUCM, CUPS  components. RTMT provides alert notification for troubleshooting  performance, for troubleshooting is way bettet than Serviceability. The objective of RTMT is to help on troubleshooting to provide the tools to solve the problems.
Rate this if helps you
Leonardo Santana
*** Rate All Helpful Responses***
