Troublesome 7921
theweeyin
Using CM 6.1.2 I have a 7921 phone and 7945 phone configured to use the same static phone number.
The phones both ring when someone rings the associated extension number, trouble is when the call is answered on the 7945 phone the 7921 continues to ring.
You can resolve the issue for a few hours if you pull the battery out of the 7921 and reset it but then the fault reappears.
I have tried using a different 7921 handset but the problem happens again.
Am thinking it could be something wrong with the config of the phones but am at a loss as to what it can be...
Aaron Harrison
Similar problem posted recently - no fix offered, I've not seen this problem myself.
I presume you're on the latest available firmware?
https://supportforums.cisco.com/message/3036106#3036106
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I am occasionally seeing the same issue, on a 7921 running 1.3.4 fw, with 7.1.3 on UCM.
Usually goes away by pressing the hang-up key on the 7921.
Will probably raise a TAC case next week when I'm back in the office...
Alistair
