Trunk h.323 between CUCM and Nortel Meridian
ribola
Hi, anyone has experience about connection of a CallManager ver.6.x or 7.0 with a PBX Nortel Meridian Option 11c via H.323 trunk?
There are issues on Nortel about sw version, license or hardware ?
There are documents relating to this solution?
Thanks, Lorenzo
mightyking
Level 6
Level 6
See if the attached file helps.
MK
thanks for your response.
I had already seen this document, but I have not found anything about connection via trunk IP H.323. I can't connect the two system via E1 Q-SIG.
The Nortel Meridian have ITG card (for trunk with remote pbx) and Signalling Server (NTDU27DC Rel.4.5).
Lorenzo
Rob Huffman
Hi Lorenzo,
Perhaps this doc may help (the basic concepts should carry over);
Nortel Communication Server 1000M Release 4.0 using H.323
Trunk to Cisco Unified CallManager Release 4.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/445274no.pdf
Hope this helps!
Rob
hi Rob, I'd like to connect and Nortel CS 1000 with h.323 trunk to a cisco 2800 sip gateway.
Nortel--h.323.--router/gateway--sip--AS
