trunkgroup with fxo
I have the configuration listed, I would like to know why the 100% of the times the port 0/0/0 is selected? what is the functionality of the
hunt-scheme? , I tested round-robin, seq, etc.... with the same result, always take the port 0/0/0.
trunk group ALL_FXO
max-retry 5
hunt-scheme longest-idle
voice-port 0/0/0
trunk-group ALL_FXO 64
connection plar 8100
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 315 pots
corlist outgoing user-celular
destination-pattern 0033.........
trunkgroup ALL_FXO 64
prefix 3
1 REPLY
Anonymous
N/A
Re: trunkgroup with fxo
Your configuration should be if you set hunting to sequential.
trunk group TEST
hunt-scheme sequential
voice-port 0/0/0
trunk-group TEST 4
voice-port 0/0/1
trunk-group TEST 3
voice-port 0/0/2
trunk-group TEST 2
voice-port 0/0/3
trunk-group TEST 1
In above config scenario voice-port 0/0/3 will be chosen first but only if its free otherwise hunting will move to port 0/0/2 and so on till it find a free voice port.
I have voice port 0/0/0 tagged as 4 assuming you are getting inbound calls on first channel.
720
