trust list not installed . tftp timeout
Hello
              I have a BE6000 running CUCM version 10 .  all my phones working perfect except one 9971 . phone status it shows trust list not installed then tftp timeout .  I have tried to delete ITL . but no ITL found . anyone help me
Aneesh
does it get DHCP alright?
does it get DHCP alright?  Also try reseting everything INCLUDING network settings... I know it sounds strange, but it has helped me in the past.
Chad
thanks chad for reply phone
phone gets correct ip and tftp address . and I have already reset many times even tried firmware upgrading
but no luck
HI can you do the following :
HI
can you do the following :-
1- On the phone Security Settings > Trust List, and delete all ITL files. If it doesn't work go to step 2.
2-do factory reset. Push # on plugin then 123456789*0#
please rate all useful infromation
thank you for the reply
    it shows no itl files installed , no ctl files also
    it seems 9971 doesnt support this key sequence for factory reset
315
