try to connect two cme together
hi,
this is a lab,
on my router 1 I have extensions 41211 and 41212,
on my router 2 I have extensions 201 and 202
I'm telling router 1 that when I call 2xx sent it to router 2
I'm telling router 2 that when I call 41xxx sent it to router 1
it's not working,
here is the config
in router 1,
dial-peer voice 1020 voip
corlist outgoing call-local
preference 1
destination-pattern 2..
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.101.1
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
phone-dn  12  dual-line
number 41212
label 41212
description User Two
name User Two
ephone  12
device-security-mode none
mac-address 58BC.2775.B6EA
type 7931
button  1:12
I have a similar config on the other router.
now when from the phone with extension 41212 I call ext: 201 I get a fast busy.
I did run a debug voice dial-peer and I get this, I don't really understand what it's saying to be honest... so I wonder if this makes sense or tells something to someone.
router 1 with ext: 41xxx
Nov  3 2013 23:04:19.632 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=41212, Called Number=, Voice-Interface=0x4BD1FB9C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_ANSWER; Calling Number=41212
Nov  3 2013 23:04:19.632 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Nov  3 2013 23:04:19.632 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=41212T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Nov  3 2013 23:04:19.632 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=41212
Nov  3 2013 23:04:19.632 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=20003 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20003
Nov  3 2013 23:04:19.632 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6170
Nov  3 2013 23:04:19.860 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2
Nov  3 2013 23:04:19.860 CAN-QC: //-1/03A89D328063/DPM/dpMatchCore:
   Dial String=2, Expanded String=2, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  3 2013 23:04:19.860 CAN-QC: //-1/03A89D328063/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=1020
   Result=1
   Result=Partial Matches(1) after DP_MATCH_DEST
Nov  3 2013 23:04:19.860 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersMoreArg:
Nov  3 2013 23:04:20.056 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=20, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20
Nov  3 2013 23:04:20.056 CAN-QC: //-1/03A89D328063/DPM/dpMatchCore:
   Dial String=20, Expanded String=20, Calling Number=
Nov  3 2013 23:04:20.056 CAN-QC: //-1/03A89D328063/DPM/MatchNextPeer:
   Result=1
Nov  3 2013 23:04:20.056 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersMoreArg:
Nov  3 2013 23:04:20.256 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=201, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=201
Nov  3 2013 23:04:20.256 CAN-QC: //-1/03A89D328063/DPM/dpMatchCore:
   Dial String=201, Expanded String=201, Calling Number=
Nov  3 2013 23:04:20.256 CAN-QC: //-1/03A89D328063/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=1020 Is Matched
   Result=Success(0) after DP_MATCH_DEST
Nov  3 2013 23:04:20.256 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1020
Nov  3 2013 23:04:20.260 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersCore:
Nov  3 2013 23:04:20.260 CAN-QC: //-1/03A89D328063/DPM/dpMatchCore:
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  3 2013 23:04:20.260 CAN-QC: //-1/03A89D328063/DPM/MatchNextPeer:
Nov  3 2013 23:04:20.260 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Nov  3 2013 23:04:20.260 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=201, Called Number=201, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  3 2013 23:04:20.260 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=201, Expanded String=201, Calling Number=201T
Nov  3 2013 23:04:20.260 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Nov  3 2013 23:04:20.260 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
   Calling Number=201, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=201
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=201T
   Result=-1
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=201
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1020 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1020
Nov  3 2013 23:04:20.264 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov  3 2013 23:04:20.268 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov  3 2013 23:04:20.268 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Nov  3 2013 23:04:20.268 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersCore:
Nov  3 2013 23:04:20.268 CAN-QC: //-1/03A89D328063/DPM/dpMatchCore:
Nov  3 2013 23:04:20.268 CAN-QC: //-1/03A89D328063/DPM/MatchNextPeer:
Nov  3 2013 23:04:20.268 CAN-QC: //-1/03A89D328063/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Nov  3 2013 23:04:20.300 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2.., Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=2..
Nov  3 2013 23:04:20.300 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Nov  3 2013 23:04:20.300 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=2..T
   Result=-1
Nov  3 2013 23:04:20.304 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Nov  3 2013 23:04:20.304 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=2..
Nov  3 2013 23:04:20.304 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Nov  3 2013 23:04:20.304 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Nov  3 2013 23:04:23.848 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=41212$, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=41212$
Nov  3 2013 23:04:23.848 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Nov  3 2013 23:04:23.848 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=41212$T
   Result=-1
Nov  3 2013 23:04:23.848 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=41212$
   Result=-1
Nov  3 2013 23:04:23.852 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
on router 2 I get
017115: Nov  4 01:31:20.159: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017116: Nov  4 01:31:20.159: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017117: Nov  4 01:31:20.159: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017118: Nov  4 01:31:20.159: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20014 Is Matched
017119: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017120: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=201, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
017121: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20014
017122: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=41212, Called Number=, Voice-Interface=0x0,
017123: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017124: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
017125: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017126: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
017127: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
017128: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017129: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
017130: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017131: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
017132: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
017133: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017134: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
017135: Nov  4 01:31:20.163: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
017139: Nov  4 01:36:03.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017140: Nov  4 01:36:03.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017141: Nov  4 01:36:03.433: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017142: Nov  4 01:36:03.433: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
017143: Nov  4 01:36:03.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017144: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
017145: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
017146: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017147: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017148: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
017149: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017150: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
017151: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
017152: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017153: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
017154: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017155: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
017156: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
017157: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017158: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
017159: Nov  4 01:36:03.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
017174: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017175: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017176: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017177: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
017178: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
017179: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
017180: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
017181: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017182: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017183: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
017184: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017185: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
017186: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
017187: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017188: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
017189: Nov  4 01:38:32.011: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
017190: Nov  4 01:38:32.015: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
017191: Nov  4 01:38:32.015: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
017192: Nov  4 01:38:32.015: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
017193: Nov  4 01:38:32.015: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
017194: Nov  4 01:38:32.015: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
any ideas why I can't call ext: 201 that's on router 2 from my phone on router 1?
Call flow :(41211,41212)r1[192.168.101.1]------SIP------>r2(201,202)
These debugs only tell us which dial-peer are getting matched but to find out more about the busy tone enable the following debugs :
  • debug voip ccapi inout
  • debug ccsip messages
Enable them on both the routers and  also attach " show run " from both .
Router 1
   Result=SUCCESS(0)
Router 2
   Result=SUCCESS(0)
Re: try to connect two cme together
this is the log on the cme with 201 and 202 extensions,
so I call from a phone on 41322 the phone on 201 and I get this debug,
this is on the cme that has numbers, 201 and 202.
I'm not sure why the ip is 10.10.10.2. my other router under telephony-service has ip 192.168.3.1 which is the phone vlan interface ip. 10.10.10.2 is the wan ip of the other router. I'm under the impression all the 10.10.10.2 should be replaced by 192.168.3.1.
192.168.101.1 is the phone vlan interface of the router with extensions 201 and 202.
020073: Nov  5 00:48:33.760: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:201@192.168.101.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.10.2:5060;branch=z9hG4bK74E6
Remote-Party-ID: "User Two" <41212>;party=calling;screen=no;privacy=off
To: <201>
Date: Tue, 05 Nov 2013 03:14:27 GMT
Call-ID: 36E21944-44FF11E3-80378E49-44504A1A@10.10.10.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 914307653-1157566947-2150796873-1146112538
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1383621267
Contact: <41212>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 185
v=0
o=CiscoSystemsSIP-GW-UserAgent 6333 6294 IN IP4 10.10.10.2
s=SIP Call
c=IN IP4 10.10.10.2
t=0 0
m=audio 19044 RTP/AVP 0
c=IN IP4 10.10.10.2
a=rtpmap:0 PCMU/8000
a=ptime:20
020074: Nov  5 00:48:33.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error ???
To: <201>;tag=974DC698-211C
Date: Tue, 05 Nov 2013 00:48:33 GMT
CSeq: 101 INVITE
Reason: Q.850;cause=63
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
020075: Nov  5 00:48:33.788: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:201@192.168.101.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
this is on the cme with numbers 41211 and 41212
020072: Nov  5 00:48:31.884: %SEC-6-IPACCESSLOGP: list 102 denied tcp 199.59.148.147(443) -> 66.130.149.13(51696), 1 packet
Received:
To: <201>
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <41212>
Expires: 180
Content-Length: 185
v=0
s=SIP Call
c=IN IP4 10.10.10.2
t=0 0
c=IN IP4 10.10.10.2
a=ptime:20
Sent:
CSeq: 101 INVITE
Content-Length: 0
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
some more information,
telephony-service
max-ephones 24
max-dn 48
ip source-address 192.168.3.1 port 2000
calling-number initiator
service dnis dir-lookup
timeouts interdigit 5
system message COMPANY ABC
network-locale CA
load 7931 SCCP31.8-4-2S.loads
load 7960-7940 SCCP41.8-4-2S.loads
time-zone 12
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name someuser secret somepassword
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Nov 04 2013 09:19:20
sip-ua
sip-server ipv4:192.168.101.1
on the other cme
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 192.168.101.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dss
system message bla bla bla
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale 4 U4 load CME-locale-fr_CA-French-8.6.2.4.tar
network-locale 1 U4
load 7931 SCCP31.9-1-1SR1S
load 7941 SCCP41.9-1-1SR1S
load 7941GE SCCP41.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7961GE SCCP41.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-5-2c
load 502G spa50x-30x-7-5-2c
load 504G spa50x-30x-7-5-2c
load 508G spa50x-30x-7-5-2c
load 509G spa50x-30x-7-5-2c
load 301 spa50x-30x-7-5-2c
load 303 spa50x-30x-7-5-2c
time-zone 12
time-format 24
keepalive 30 auxiliary 4
voicemail 399
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret somepass
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
sip-ua
credentials username abc password 123
keepalive target dns:xyz.voip.ms
authentication username abc password 123
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
registrar dns:xyz.voip.ms expires 3600
sip-server dns:xyz.voip.ms
host-registrar
so this cme is connected to voip.ms and all is working fine.
I just want the other router to connect to this one when calling 201 and 202 extensions and this one to connect to the other one when calling 41211 and 41212 numbers.
this is all in a lab so I can try whatever that can help.
thanks.
251
