Trying to do a conference using a Services button
I am trying to initiate the Live Record feature with a simple press of a button.  However, I'm having some challenges.  The idea is to have an xml or jsp application that will perform four keystrokes - Conference, #, #, Conference.  Using examples that I have come across, I was able to set up a jsp file and using the CiscoIPPhoneExecute object with a Key:n URI, I can get a single keypress to work.  However, if I try to string together more than one, I get "XML Error [4]: Parse Error".
Any suggestions or on-line references that will give me any ideas?
Michael
Everyone's tags (2)
Re: Trying to do a conference using a Services button
Are you posting more than one execture function at the same time?  You might want to try and braking them up into multiple POSTs to get that to work.
Here's what I have in my JSP file:
<%@ Language=JavaScript %>
Response.ContentType = "text/xml";
//The end?
If I wanted to simply have it enter two stars, how would I modify this?
Thanks!
271
