Trying to get Brazil dial-peers correct for additional cellular digit
I cannot get cellular calls to Sao Paulo to go through. Any insight would be appreciated. ! dial-peer voice 191 pots description Emergency Calling destination-pattern 19. port 0/0/0:1 forward-digits 3 ! dial-peer voice 9191 pots description Emergency Calls with prefix 9 dialed destination-pattern 019. port 0/0/0:1 forward-digits 3 ! dial-peer voice 98 pots description Local calls 8 digit destination-pattern 0[2-9]....... port 0/0/0:1 forward-digits 8 ! dial-peer voice 900 pots description International Calls destination-pattern 000T port 0/0/0:1 prefix 00 ! dial-peer voice 909 pots description Sao Paulo Cellular Calls destination-pattern 043119[6-9]....... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 300 pots description 0300 local-rate dialing destination-pattern 0300....... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 800 pots description 0800 toll-free numbers destination-pattern 0800....... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 801 pots description 0800 toll-free numbers destination-pattern 0800...... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 301 pots description 0300 local-rate dialing destination-pattern 0300...... progress_ind setup enable 3 progress_ind alert enable 8 port 0/0/0:1 forward-digits all ! dial-peer voice 908 pots description Long Distance Calls destination-pattern 0043[1-9].[2-9]....... port 0/0/0:1 forward-digits 13
Everyone's tags (3)
Is it possible that mobile
Is it possible that mobile phone calls to Sao Paulo don't need to go through a long distance carrier?  Are you in the same geographic code as Sao Paulo?
The configuration was correct
The configuration was correct. Telco did not have the configuration correct on their side.
217
