Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Trying to log into VM box instead of transferring to users VM
First:
Cisco Unity Connection version: 8.6.1.20000-109
CUCM: System version: 8.6.1.20000-1
I have an issue with Unity.  Whenever I dial an extension that has a VM box, instead of transferring into the called numbers box, I get prompted to enter my PIN for my mailbox.
Any help would be greatly appreciated.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Trying to log into VM box instead of transferring to users V
Had the same issue.
Make sure you VM profile mask is sending the correct extension digits IE XXXX
Now go into CUC and select forwarded transfer and rule 1 change the action from attempt transfer to attempt login, save then back into rule 1 and change to attempt login again. Reboot if no affect
Hall of Fame Super Silver
SIP or SCCP integration?
Make sure "use external phone number mask" is not cheked either on the Route Pattern with SIP or Hunt Pilot with SCCP.
Chris
Chris,
Thanks for the quick response.  I am using SCCP and checked the Hunt Pilot and "Use External Phone Mask" is NOT checked.
Another thing to check is make sure you have default Routing Rules on UCON and no weird rule was applied.
Chris
I don't see anything that looks weird.  This worked as it should at one time, but does not now.  I am not sure what changed, but I cannot find anywhere that even remotely looks like the right option to look at.
What are you seeing on Port Viewer?
Is the VM Profile on CUCM configured properly?
Chris
The VM profile looks good.  I have not installed the Port Viewer yet, but will first think in the morning.  I have to run out to take care of a few things.  Thanks for your help today.
Had the same issue.
Thanks to Matt for the answer and Chris for all the help (and for showing me the Real Time Monitoring Tool).  I changed the Forwarding Rule to "Attempt Transfer" (it was on Attempt Sign In) and all is back to normal.
Thanks again,
Steve
289
