Community Member
Turn off phones after 9PM
I have a pool of sccp analog phones off of a VG224 registered with CCM 6.1.2. I need to disable inbound calling to this group of phones after 9PM. The phones must be able to make calls, but cannot receive calls after 9PM.
I could use ToD routing for the partition that these phones belong to, but then they wouldn't be able to make calls either, right? Any other ideas?
Jeff
1 REPLY
Hall of Fame Super Silver
Re: Turn off phones after 9PM
ToD is the way to go, and you will be able to make outbound calls if you configure your CSS/PT correctly. The only PT that should be using ToD routing is the one applied to the analog phones, the CSS applied to the phones should be the regular one which allows outbound calling.
HTH,
Chris
117
