Turn off Unity and Callmanager
OK we have a power off tonight in the data center. how do I do a graceful shutdown of Unity and Callmanager?
Re: Turn off Unity and Callmanager
Version is 7x
utils system shutdown for cucm and unity connection.
Start...shut down in windows for unity.
As far as order of Ops. Shouldn't matter but I like to make sure I start the cucm pub first when power is restored. I would also shut it down last. But I have no tech reason for that. Just preference.
Hth.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Unity doesn't matter.  If you have failover, it's easier to shut down the failover first then the primary.  Then boot the primary first and failover server once primary is online and taking calls.
Hailey
Please rate helpful posts!
Thanks, I started the server with the Primary up first, seems to make things easier that way, I just waited 5 minutes between server startup.s
I wish it were windows sometimes, but Linux is what I got!!!
I found it after some more reading......Read who would have thought that it would help..
OS Adminitrator, Settings, Version, Shutdown....
Shudown under Version? who thougth that one up????
Thanks for the help!
983
