11-06-2009 01:58 AM - edited 03-15-2019 08:22 PM
I have two CCM servers running on versions 4.1 and 4.2.
Can I integrate these two systems to a single enterprise LDAP ?
Thannks,
Nalakak
Solved! Go to Solution.
11-06-2009 07:13 AM
Simply create 2 separate cisco OUs in AD for the users of each cluster, you can use the same search base if you want.
Then just run the AD plugin
java
if this helps, please rate
11-06-2009 07:13 AM
java
11-08-2009 08:54 PM
Thanks for the answer. It resolved my issue.
On of the CCM has IPCC attached to it. Is there any concerns with IPCC when you integrate with AD ?
Nalakak.
11-08-2009 10:41 PM
You should be fine with IPCC and AD. What versions of IPCC?
