Two CCME Routers at a Single Location
peternnaji
Hi all,
Am trying to propose a CCME solution with two callmanagers at a site as shown in the attached diagram. I understand it can work perfectlly with an enterprise solution ( Cisco Callmanager Server) but i am price conciuos here. I want to know if this slution is feasible and the likely consequenncies after implementing it.
I will appreciate your responses.
Walter Solano
Level 7
Level 7
Hello Peter,
You can have two CME router in the same location, its a very used desing. The only detail is that you are not going to have any kind of redundancy in case that one of them fail. Another important think to consider is that you will have to configure dial-peers to call between the CCMEs. This is a very difficult setup but it can be done.
Walter Solano
CCNA Voice
Cisco UCCX Specialist
