two jtapi-apps on the same terminal
hi experts,
I have the following problem:
I have a working JTAPI Application running on a bunch of IP phones, mostly 7911, 7962, 7970 terminals.
Now I need an additional service to create some XML data that I can push to the phones. But the push is done by an external source, for instance an asterisk telephone server. The *-server calls the jar file containing the JTAPI functionality and try to push an XML <CiscoIPPhoneExecute> object via CiscoTerminal.sendData(xml) to the terminal.
Then I get the following error:
at com.cisco.jtapi.TerminalImpl.getButtonPressedEnabled(CTQF)
at com.cisco.jtapi.TerminalImpl.getDeviceState(CTQF)
at de.aco.al.Start.<init>(Start.java:70)
at de.aco.al.Start.main(Start.java:25)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
The weird thing is. I use the same code in the working application and everything works fine...
CiscoTerminal ct = (CiscoTerminal) term;
int state = ct.getDeviceState(); System.out.println("state:" + state);
ct.sendData(xmlResponse);
The code already interrupts at the getDeviceState method!
Any clues what could be the reason for this behaviour?
Cheers and thx in advance for your mostly appreciated help!
Peter
1 REPLY
Re: two jtapi-apps on the same terminal
Hi there,
solved the problem.
I did not place an observer on the phone. hence i was unable to control it. I do not know why an observer is necessary to use the CiscoTerminal.sendData method but anyway. Solved!
Cheers Peter
209
