Community Member
Two Lines on VG204 ports why ? and does this get used?
Have a customer who has assigned secondary DN to ports on their VG204 analogue gateways.
If he dials the first number everything is ok
When he dials second they receive network not availble tone.
Questions
  1. When / why would one use a secondary line on Analogue port ?
  2. What is the purpose of the second line on the anaologue ports
Allan
Hall of Fame Super Gold
Re: Two Lines on VG204 ports why ? and does this get used?
You are talking about a secondary NUMBER, not a secondary LINE.
Lines and numbers are NOT the same thing.
The reason why the secondary number cannot be reached, is because your client has got the wrong configuration, possibly for the wrong reasons.
To answer to your 1. and 2.  questions that are really the same:
Secondary numbers are meant to help during numbering changes, when the external number does not map the internal, and other situations.
Please remember to rate useful posts clicking on the stars below.
Community Member
Actually
Im talking about a secondary line - thats what is says in CUCM "LINE" LINE 1,2,3,4 etc as per below
From a config perspective The lines have all the same properties as the first line except DN
What im really after  iseither Cisco guide or consise information that articulates clearly the purpose  of the secondary lines - so I can advise the client correctly
Unassigned Associated Items ----------
2 Line [2] - 2481 in AUS--INTERNAL
3 Line [3] - 2482 in AUS--INTERNAL
4 Line [4] - Add a new DN
Maybe the client wants that extension to answer to two different numbers for some reason, only they may know.
However from the display is unassigned, hence not working.
Consider, multiple DNs on a buttonless, displayless instrument, does not make much sense.
185
