12-19-2011 09:24 AM - edited 03-16-2019 08:36 AM
we want to connect a Siemens Hicom 300E with the Cisco CUCM 8.5, we need two QSIG-Trunks, each trunk ends on one of two Cisco 2901 with VWIC3-2MFT-T1/E1. The port for each trunk is on one of the E1-Ports.
I configured both ends the same as the other.
The QSIG variant ist ECMA v1.
The problem is that the realiability on one of those trunks are very poor, one link periodically loses the Layer 2 connectivity.
We have no Layer 1 problems, everything is measured.
We exchange everything, cable, ports, router E1-Ports and siemens-ports, also between themselves ( the problem is not situated on one router or E1-Port, if you change to the other the problem move on.
The siemens technician found no config problem on his side, but he has also Layer 2 problems on one trunk.
What might be the problem?
Thanks a lot
12-19-2011 10:26 AM
it seems to be a problem with the clocking, but im not sure what the correct clocking is, it might be a configuration "issue" on the siemens side.
Has anybody experience or best practices in connecting multiple spans from Siemens Hicom 300E to Cisco?
Thanks a lot
12-19-2011 01:36 PM
Can you post the config of the 2901.
Does the hicom clock from the pstn
Alex
12-20-2011 08:19 AM
"Does the hicom clock from the pstn?"
i will ask the technician, the last statement was that the hicom set the clock, but im not sure if that means automatically pstn.
config 2901 ( same config on the other router ):
version 15.1
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service linenumber
service sequence-numbers
service counters max age 5
hostname xxxx
boot-start-marker
boot-end-marker
card type e1 0 0
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone MET 1 0
clock summer-time MEST recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/1
no ipv6 cef
no ip source-route
ip cef
ip domain name xxxx
ip name-server xxxx
isdn switch-type primary-net5
voice-card 0
voice service voip
fax protocol pass-through g711alaw
modem passthrough nse codec g711alaw
license udi pid CISCO2901/K9 sn FGL1546285L
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
description PSTN
controller E1 0/0/1
description qsig
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address xxxxx
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 xxxxx
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
cptone DE
voice-port 0/0/1:15
cptone DE
ccm-manager fallback-mgcp
ccm-manager redundant-host xxxx
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server xxxx
ccm-manager config
mgcp
mgcp call-agent xxxx 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 100 pots
service mgcpapp
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 101 pots
service mgcpapp
direct-inward-dial
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 0 0
logging synchronous
transport input telnet ssh
scheduler allocate 20000 1000
ntp server ...
end
12-20-2011 08:41 AM
This router is taking its clock from the HICOM
Config looks OK
I would add
network-clock-select 2 E1 0/0/0
Now if the 0/0/1 interface fails then the 0/0/0 will become the clock source.
Alex
12-21-2011 12:06 AM
thanks for your reply.
The E 0/0/0 is currently not in use, i will add that statement if the port goes up.
12-21-2011 01:09 AM
"Does the hicom clock from the pstn"
Hicom clocks from pstn
12-30-2011 12:29 AM
The latest information about the pbx config is that both qsiq work like a bundle, they can't
separate the qsiq, because the same call routing from pbx to another pbx can only be situated exactly on one or a bundle of trunks.
07-04-2012 04:03 PM
by the way, the problem is solved. It was a defect at the Siemens PBX
