02-28-2012 07:07 AM - edited 03-16-2019 09:49 AM
Hello its configure two SIP Trunks in the same router, because i only have one sip-ua on the router to configure.
I using this IOS : Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Leonardo Santana
02-28-2012 07:45 AM
Leonardo Santana,
You can simply use session target on the dial-peer rather than the sip-ua.
HTH,
Chris
02-28-2012 08:48 AM
if i need to use the SIP UA, for the authentication for the ITSP?
02-28-2012 09:01 AM
You can do that at dial-peer level as well. Check out
Configuring Multiple Registrars on SIP Trunks
HTH,
Chris
