Two SIP Trunks
Hello its configure two SIP Trunks in the same router, because i only have one sip-ua on the router to configure.
I using this IOS : Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Leonardo Santana
Hall of Fame Super Silver
Two SIP Trunks
Leonardo Santana,
You can simply use session target on the dial-peer rather than the sip-ua.
HTH,
Chris
Two SIP Trunks
if i need to use the SIP UA, for the authentication for the ITSP?
Two SIP Trunks
You can do that at dial-peer level as well. Check out
Configuring Multiple Registrars on SIP Trunks
http://www.cisco.com/en/US/partner/docs/ios-xml/ios/voice/sip/configuration/15-1mt/Configuring_Multiple_Registrars_on_SIP_Trunks.html
HTH,
Chris
248
