Community Member
Two Unity Express modules on the same chassis
is it supported to have two Unity Express modules (one NM-CUE + one NME-CUE, for example) on the same router chassis?
If yes, is there any requirement, like both modules have equal hardware and/or run the same software version?
Thanks.
Jefferson
1 REPLY
Community Member
Re: Two Unity Express modules on the same chassis
if cisco would allow it then we don't really need to buy a unity connection from them
119
