UC 500 and Unified Messaging
Is it possible to have Unified Messaging with Unity Express that comes with Unified Communication 500 Series.Any documents/white sheets to support or deny it?If not what would the best option to get this feature for a small scale solution - as small as 15 users.
Anupama
Re: UC 500 and Unified Messaging
The UC500 only supports Integrated Messaging. If you want something that provides Unified Messaging take a look at CME and StoneVoice. Also, do not rule out CME and Exchange 2007 with SP1.
Hi Kevin
Thanks for the reply - What does Integrated Messaging imply? On the Data sheet, it sounds a lot like Unified Messaging? Is it only voicemails showing up on an email client?Not Fax or other things?
Anupama
Hi, new CUE features can be found here:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_note09186a0080857e89.html#wp153937
This includes fax in your voice mailbox accessible via a mail reader.
167
