Community Member
UC 500 - CLI for outgoing calls
Could anybody confirm that the number field under the ephone-dn is used to populate the CLI field for an outgoing Q931 call? I'm having difficulties using different CLI values for different phones and I want to double check I'm manipulating the correct field.
For example, in the ephone-dn below should I see 01234 123456 as the CLI?
ephone-dn 21 dual-line
number 01234 123456 secondary 212
label 01234 123456
description Desk Twelve
name Desk Twelve
call-forward busy 100
call-forward noan 100 timeout 10
Jed
Community Member
Re: UC 500 - CLI for outgoing calls
Typical, as soon as I post something I find the answer. I need to focus on the dial plan a little more and look at my translation-rule statements I now see:
voice translation-rule 1111
rule 15 /.*/ /01234 123456/
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
Can I simply remove the translate calling statement?
I'm not 100% sure how the DNs need to be configured yet as each phone will have a DDI when logged in via EM.
Jed
Hall of Fame Super Gold
Yes, basically you use the translation rules to present the correct calling number.
The alternative is to use "dialplan-pattern" but I don't like it very much beside it causes issues with the CUE if you have it.
Community Member
Thnaks, I sorted this today so now it's working fine.
I did have a quick go at trying a translation profile on the ephone-dn for the outgoing CLI but it didn't seem to work. It was along the lines of:
ephone-dn 8 dual-line
number 504 no-reg primary
label 504
description abc
name abc
translation-profile outgoing TRANSLATE-CLI
but I never got any match against the CLI for the outgoing call. Am I missing anything here?
Jed
I've seen images where translation-profile under ephone-dn simply doesn't work.
Try to have it under dial-peer or voice-port as long as possible.
156
