UC 500 Expansion Module issue
  I have IP Telephony setup in UC 500.The issue is that its not supporting the Expansion Module 7916,only supporting 7914.When I type the command
type 7961 addon 1   its only showing 7914.The Version details given below.
sh telephony-service
CONFIG (Version=4.2(0))
Version 4.2(0)
Cisco Unified Communications Manager Express
sh ver
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW7, RELEASE SOFTWARE (fc2
do I need to upgrade the version.if yes please suggest me the appropriate version.
Thanks in Advance...
Nithin Louis.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Hi Nithin,
The problem here is that the 7916 is not supported on any
system (UC500, CME or CUCM) with the 7961 IP Phone.
From the 7916 Data sheet;
The Cisco Unified IP Phone Expansion Module 7916 extends the capabilities of the Cisco Unified IP Phone 7962G, 7965G, and 7975G models with additional buttons and an LCD display. With this expansion module, you add 12 physical keys with access to 12 additional keys through the page keys for a total of 24 buttons to the existing 6 buttons of the Cisco Unified IP Phone 7962G and 7965G (Figure 2) models and the existing 8 buttons of the Cisco Unified IP Phone 7975G. You can use up to two Cisco Unified IP Phone Expansion Module 7916 modules (Figure 3) with the Cisco Unified IP Phone 7962G, 7965G, and 7975G models.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468673.html
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Green
Here is the link to the software compatability matrix for
CME 4.2
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme42spc.htm
As you can see the 7916 is not supported in this version
You will need to upgrade to at least
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme43spc.htm
CME 4.3 where support for 7916s begins
This 3rd link is the full version list
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Hi Nithin,
Cheers!
Rob
Green
CME 4.2
Alex
372
