Community Member
UC 520 factory restore
How can I reset the UC520 back to it's default configuration.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: UC 520 factory restore
Check if there is a default configuration file in flash doing "dir". If there is, do "copy startup-config", and reload.
Community Member
Yes it does!!! You are awesome!
Thank you for the nice rating and appreciation, good luck!
211
