UC 540 Fax issue
  I have telephony setup with UC 540.I have to configure analog fax and I connected to the fxs port of the UC using RJ11.But after configuration fax calls not happening.Getting disconnecting ....shows Busy in telephone set while making calls to fax .
The Fxs port status same like on-hook whenever I am making call to fax(Connected to port 0/0/0) .I am attached Sh_run and debug Voice CCapi inout & Debug VPm signal.
My fax number 436 .
I am using the Version of UC 540 is  UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(24)SB, RELEASE SOFTWARE (fc1)
CME version is 7.1
Router#sh voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxs-ls      up    dorm on-hook  idle     y
0/0/1           --  fxs-ls      up    dorm on-hook  idle     y
0/0/2           --  fxs-ls      up    dorm on-hook  idle     y
0/0/3           --  fxs-ls      up    dorm on-hook  idle     y
0/2/0:15        01  isdn-voice  up    dorm none     none     y
0/2/0:15        02  isdn-voice  up    dorm none     none     y
0/2/0:15        03  isdn-voice  up    dorm none     none     y
0/2/0:15        04  isdn-voice  up    dorm none     none     y
0/2/0:15        05  isdn-voice  up    dorm none     none     y
0/2/0:15        06  isdn-voice  up    dorm none     none     y
0/2/0:15        07  isdn-voice  up    dorm none     none     y
0/2/0:15        08  isdn-voice  up    dorm none     none     y
0/2/0:15        09  isdn-voice  up    dorm none     none     y
0/2/0:15        10  isdn-voice  up    dorm none     none     y
0/2/0:15        11  isdn-voice  up    dorm none     none     y
0/2/0:15        12  isdn-voice  up    dorm none     none     y
0/2/0:15        13  isdn-voice  up    dorm none     none     y
0/2/0:15        14  isdn-voice  up    dorm none     none     y
0/2/0:15        15  isdn-voice  up    dorm none     none     y
0/2/0:15        17  isdn-voice  up    dorm none     none     y
--More--                           0/2/0:15        18  isdn-voice  up    dorm none     none     y
0/2/0:15        19  isdn-voice  up    dorm none     none     y
0/2/0:15        20  isdn-voice  up    dorm none     none     y
0/2/0:15        21  isdn-voice  up    dorm none     none     y
0/2/0:15        22  isdn-voice  up    dorm none     none     y
0/2/0:15        23  isdn-voice  up    dorm none     none     y
0/2/0:15        24  isdn-voice  up    dorm none     none     y
0/2/0:15        25  isdn-voice  up    dorm none     none     y
0/2/0:15        26  isdn-voice  up    dorm none     none     y
0/2/0:15        27  isdn-voice  up    dorm none     none     y
0/2/0:15        28  isdn-voice  up    dorm none     none     y
0/2/0:15        29  isdn-voice  up    dorm none     none     y
0/2/0:15        30  isdn-voice  up    dorm none     none     y
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
0/4/0           --  moh-imd     up    dorm idle     idle     y
50/0/2          1      efxs     up    dorm on-hook  idle     y
50/0/3          1      efxs     up    dorm on-hook  idle     y
50/0/4          1      efxs     up    dorm on-hook  idle     y
50/0/6          1      efxs     up    dorm on-hook  idle     y
50/0/44         1      efxs     up    dorm on-hook  idle     y
--More--                           50/0/45         1      efxs     up    dorm on-hook  idle     y
50/0/5          1      efxs     up    dorm on-hook  idle     y
50/0/5          2      efxs     up    dorm on-hook  idle     y
50/0/5          3      efxs     up    dorm on-hook  idle     y
50/0/5          4      efxs     up    dorm on-hook  idle     y
50/0/5          5      efxs     up    dorm on-hook  idle     y
50/0/5          6      efxs     up    dorm on-hook  idle     y
50/0/5          7      efxs     up    dorm on-hook  idle     y
50/0/5          8      efxs     up    dorm on-hook  idle     y
50/0/1          1      efxs     up    dorm on-hook  idle     y
50/0/1          2      efxs     up    dorm on-hook  idle     y
50/0/1          3      efxs     up    dorm on-hook  idle     y
50/0/1          4      efxs     up    dorm on-hook  idle     y
50/0/1          5      efxs     up    dorm on-hook  idle     y
50/0/1          6      efxs     up    dorm on-hook  idle     y
Please let me know anything missing from myside......
Thanks in Advance....
Nithin Louis.....
VIP Super Bronze
Re: UC 540 Fax issue
Hi Nithin,
Can you describe your call setup. Where are you calling the fax machine from...
EG..PSTN---------->UC540-----Fax
or
CCM-------UC540---Fax
There is no debug voip Ccapi inout on the attached..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
UC 540 Fax issue
Thanks for your reply.....Th call setup is PSTN----->UC540----->FAX
I have mentioned below the debug Voice CCAPI inout.......
calling number is : 933512183...and called number is 17386436(ext.length is 3 ie,436)
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.05.21 14:10:37 =~=~=~=~=~=~=~=~=~=~=~=
002635: May 21 21:08:07.827: //-1/E5F3C1D3816D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=933512183
   cisco-anitype=4
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=17386436
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
002636: May 21 21:08:07.827: //-1/E5F3C1D3816D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x87C2D094, Call Info(
   Calling Number=933512183,(Calling Name=)(TON=Subscriber, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=17386436(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=11, Progress Indication=NOT END TO END ISDN(1), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
002637: May 21 21:08:07.827: //-1/E5F3C1D3816D/CCAPI/ccCheckClipClir:
   In: Calling Number=933512183(TON=Subscriber, NPI=ISDN, Screening=Network, Presentation=Allowed)
002638: May 21 21:08:07.827: //-1/E5F3C1D3816D/CCAPI/ccCheckClipClir:
   Out: Calling Number=933512183(TON=Subscriber, NPI=ISDN, Screening=Network, Presentation=Allowed)
002639: May 21 21:08:07.827: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002640: May 21 21:08:07.827: :cc_get_feature_vsa malloc success
002641: May 21 21:08:07.827: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002642: May 21 21:08:07.827:  cc_get_feature_vsa count is 1
002643: May 21 21:08:07.827: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002644: May 21 21:08:07.827: :FEATURE_VSA attributes are: feature_name:0,feature_time:2283649280,feature_id:3920
002645: May 21 21:08:07.827: //3203/E5F3C1D3816D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=933512183(TON=Subscriber, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=17386436(TON=Subscriber, NPI=ISDN))
002646: May 21 21:08:07.831: //3203/E5F3C1D3816D/CCAPI/cc_process_call_setup_ind:
   Event=0x875C41B8
002647: May 21 21:08:07.831: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6436
002648: May 21 21:08:07.835: //3203/E5F3C1D3816D/CCAPI/ccCallSetContext:
   Context=0x8816F1DC
002649: May 21 21:08:07.835: //3203/E5F3C1D3816D/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 3203 with tag 11 to app "_ManagedAppProcess_Default"
002650: May 21 21:08:07.835: //3203/E5F3C1D3816D/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
002651: May 21 21:08:07.839: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 436
002652: May 21 21:08:07.839: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002653: May 21 21:08:07.839: : updating existing feature vsa
002654: May 21 21:08:07.839: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002655: May 21 21:08:07.839:  feature call basic
002656: May 21 21:08:07.839: //3203/E5F3C1D3816D/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
002657: May 21 21:08:07.839: //3203/E5F3C1D3816D/CCAPI/ccCallDisconnect:
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
002658: May 21 21:08:07.839: //3203/E5F3C1D3816D/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
002659: May 21 21:08:07.975: //3203/E5F3C1D3816D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x87C2D094, Tag=0x0, Call Id=3203,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
002660: May 21 21:08:07.975: //3203/E5F3C1D3816D/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
002661: May 21 21:08:07.979: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002662: May 21 21:08:07.979: :cc_free_feature_vsa freeing 881DB8F8
002663: May 21 21:08:07.979: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002664: May 21 21:08:07.979:  vsacount in free is 0
Router#
Router#
Router#
Router#
UC 540 Fax issue
  Is this configuration is correct??or need any changes???
Nithin Louis...
VIP Super Bronze
UC 540 Fax issue
Do you have an analogue phone you can connect to the port 0/0/0. Can you check if you have a dial-tone on that port.
Can you also test with this xlation rule...
voice translation-rule 1
rule 4 /^17386436/ /436/
UC 540 Fax issue
Thank you once again for your quick response......i tried translation rule ...but the same result.....
Let me check with analog phone.....Have to arragnge that..will update you with the result......
If no ring tone we can have the conclusion that the card is faulty..?right?
VIP Super Bronze
UC 540 Fax issue
Probably, because its giving a busy signal. Can you try and do a shut/no shut on the voice-port.
voice-port 0/0/0
shut
no shut
and try again
468
