UC on UCS, VMWare Tools, and shutdowns
The UC linux appliances have VMWare tools embedded, which supports the shutdown guest function via VMWare.  In trying this a few times in the lab, I've noticed that if you use this, it causes VMWare to term the O/S rather than shutting down the applicaiton first and then terming the O/S.
My question is....is this dangerous to do?  Will using this cause damage to the V/M?  Can it cause service interruptions?  Database corruption?
TIA
Cliff
1 ACCEPTED SOLUTION
Re: UC on UCS, VMWare Tools, and shutdowns
Hi Cliff,
After talking to our internal Development resources got the below information.
VMTools shutdown is not same as Linux shutdown (CLI command that we normally use in case of VOS) for Cisco UC VOS based apps.
It is not advised since we cannot assure the system’s integrity post such operation.
We realize that the customer in this case might be trying to automate such operation in a mass deployment environment.
But for time being please use system cli for such operation.
Hope it helps.
Anand
Pls rate helpful posts !!
Hi Cliff,
Please refer the "VMware Feature Support" in the below link for UC apps,
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
Hope it answers your query.
Anand
Unfortunately, it doesn't.
Even when looking on VMWare's web site, there is no indication that shutting down a VM through VMTools is a "feature" and even if it is, there is no indicated name for it.  VMWare tools isn't even mentioned anywhere on that page.
It would be really nice if someone with ties back to the business unit (specifically around CUCM and UCxN) could weigh in on this.
Cliff
No, sorry.
I'm trying to find out if simply using VMWare tools to execute the Shutdown Guest System will damage anything when used with Cisco Linux appliances such as CUCM and UCxN.  The document you linked doesn't address that.
Hi Cliff,
Hope it helps.
Anand
That's what I needed.  Thank you!
1529
