10-07-2013 11:21 AM - edited 03-16-2019 07:45 PM
i want to configure the conference hardware on the uc500, but it doesn't work :
The configuration :
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate profile 1 register confdspl
keepalive retries 5
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
associate application SCCP
And i got that :
sh dspfarm profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 1
Number of Resource Available : 1
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
VILLE-UC540#Connection closed by foreign host.
I don't know why the SCCP is "NOT ASSOCIATED" ...
If somebody has an idea...
Thanks for all
best regards,
Guillaume
10-07-2013 11:27 AM
The UC5XX are not a supported media resource for CUCM, you can configure those resources for CME on the UC5XX, but not for CUCM, that's not supported.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-07-2013 11:32 AM
thanks for the answer, but it's not for CUCM it's for CME on UC540 ...
Guillaume
10-07-2013 11:55 AM
OK, have you configured it under telephony-services??
Have you tried doing a shut/no shut of the profile?
java
10-07-2013 01:57 PM
Yes i configured this under telephony-services :
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 3
sdspfarm tag 1 confdspl
conference hardware
and yes i tried doing shut/no of the profile but it changes nothing
10-07-2013 09:00 PM
sccp local [interface]
sccp ccm x.x.x.x identifier 1 version [version]
sccp ccm group 1
bind interface [interface]
exit
sccp
codec [codec-flavor]
maximum sessions 1
sccp ccm group 1
associate profile 1 register [name]
telephony-service
conference hardware
sdspfarm units 1
sdspfarm tag 1 [name]
create the ephone-dn for conference
Are you really using a CME version 3?
Check if there's a later version available on the following command:
If there's a later version, use it.
Then capture some show commands:
-show dspfarm all
-show ephone-dn conference
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
10-08-2013 09:30 AM
Hi ,
i change and now there is configured :
sccp ccm 10.1.1.1 identifier 1 version 7.0
sccp
but it still don't work :
show dspfarm all :
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 4 28.3.5 UP N/A FREE conf 1 - - -
Total number of DSPFARM DSP channel(s) 1
and show ephone-dn conference :
type active inactive numbers
Ad-hoc 0 2 550
DN tags: 150
Ad-hoc 0 2 551
DN tags: 151
Ad-hoc 0 2 552
DN tags: 152
Ad-hoc 0 2 553
DN tags: 153
I don't understand
Thanks for all !
Best regards,
