UC500 and CUCM 7
I'm looking at solutions for a customer and just want to be very sure I'm correct:
Can UC500 integrate at all with CUCM via a SIP trunk or as H.323 gateway? If not, why is it different? From what I understood it is just CME, or am I wrong?
Thanks for your help
Re: UC500 and CUCM 7
I believe it is the same CUCME:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/srnd/design/guide/intcmecm.html
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
The answer is Yes, you can integrate your UC520(CME) with you CUCM using a SIP Trunk, H.323 Trunk or H.323 gateway. In case that you would like to use the CUE as small voice mail solution integrated with you CUCM you need to do a JTAPI integration this process requires an especial license in the CUE.
Walter Solano
CCNA Voice
Cisco UCCX Specialist
From a support perspective, UC520 integration with CUCM IS NOT A SUPPORTED DEPLOYMENT unless you have a CUBE (Cisco Unified Border Element) in between them. UC520 can ONLY integrate with other UC520s or CUCME, NOT CUCM.
From a configuration perspective, it is a straight forward integration like with any other CUCME box and CUCM (H323 / SIP).
HTH.
Harmit.
-- Regards, Harmit.
1107
