UC500 and IVR
I am wanting to setup IVR on my company's Demo UC500, for testing. Can this be done with the UC500?
Hall of Fame Super Gold
Re: UC500 and IVR
Yes, you can have IVR with either CUE, or TCL/IVR.
Re: UC500 and IVR
Thank you, is there some documentation to set this up for the CUE side? Specifically, since the UC500 uses the Integrated Service Module, I couldn't find the licenses for it.
Re: UC500 and IVR
Hi, I'm not sure about the licenses, I think are needed only when you use IVR in conjunction with a VXML server, with the NM-CUe on an ISR router.
If you write simple IVR scripts using the script editor only, on the UC520, I don't think any license is required.
Please rate post if it does!
Re: UC500 and IVR
Heres what I get when I try to add a db profile:
UC500-CUE(config)> ccn subsystem edbs dbprofile default
Operation not allowed with current installed license
I see there is a 2 port license file in the 3.0.3 CUE area, but I get the same error when that is installed...
Re: UC500 and IVR
I think you've to clarify with a cisco UC500 PM if they support DB interaction IVR.
Possibly not.
Re: UC500 and IVR
OK, thanks!!
Re: UC500 and IVR
Response That I got from the UC500 team when I asked a while back is that the Licensed IVR features for CUE will Not be supported on the UC500.
Re: UC500 and IVR
OK, thanks for the info. I was thinking this was the case.
909
