UC500 - Called Name Display
Hi there i am installing an UC500 at a customer site. The CCME version of this UC500 is 4.2.3. I implemented the Called Name Display like it is mentioned on the Cisco site. First activate the service DNIS Dir-Lookup and also activated the service DNIS Overlay. Then put the MSN number of the ISDN line in the Directory Entry. But when somebody calls the extension i only see the Caller ID and not the Called ID. Could somebody help me with this ?
Hall of Fame Super Gold
Re: UC500 - Called Name Display
Hi, please check with "debug isdn q931" and "term mon" that the called number is the same as your directory entry.
Thanks for your quick reply. I am not at the customer site right now. But i put in different versions of the numbers, so i put in :
0451234567 name Customer A
00451234567 name Customer A
I don't think numbers will be advertised like:
000451234567
Hope hearing more from you ?
Well, you have to check. For our CME's we always setup a VPN or something to access device from remote, because customers always want some change and it's too impractical to get on site for any small need.
OK i have looked at the data you mentioned and see the correct MSN number coming in. The same as i entered in the Directory. But still no called name display.
Which exact IOS are you running ?
My IOS version is:
12.4(r11)XW
Hi, can you upgrade to 12.4(11)XW5? What you have is very buggy.
I will do that this afternoon and will report back my findings. Thanks for your quick reply.
I am having similar issues, I wonder if you could confirm if you got this working. More importantly, if you did, please share as I am going nuts trying to work this out!
Thanks in advance!
351
