Community Member
uc500 e1 unknow number
                   Hello
Please help me
I m have cisco uc540 with card
Cisco vwic2-1mft-t1/e1  and e1 with 15 trunk
and ip phone 7945g
When i m try out call  and see on  phone "unknow number"
config
Building configuration...
Current configuration : 26598 bytes
! Last configuration change at 17:09:03 ZP4 Mon Jan 27 2014 by root
! NVRAM config last updated at 17:07:34 ZP4 Mon Jan 27 2014 by root
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC540
boot-start-marker
boot-end-marker
card type e1 0 2
enable secret 4 BPLnn4zPebCYELEG9US9KrGij4sS4p7fN8yjtJik5m2
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone ZP4 4 0
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
crypto pki trustpoint TP-self-signed-798949418
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-798949418
revocation-check none
rsakeypair TP-self-signed-798949418
crypto pki certificate chain TP-self-signed-798949418
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 37393839 34393431 38301E17 0D313430 31323330 38343333
  325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3739 38393439
  34313830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  8EF06865 C1A66735 40586780 4D936B9B A5DA684F 8E31CE5C 709966FE 6FD99EB1
  37A56A1B 415DA055 13B2DF0F A747802F 53CF6525 36AB01C5 168D7766 6728DA38
  F7228930 5A86A81A BA606ACF 02B1368F C960D9AD 64D498E1 F9DA744A 6FF8F1C9
  7A0A6EE8 02985E7C C1CEF070 7E4BE5D8 FFE1D86F 23AB6F57 9E6F1EB0 D577DE01
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 16801403 1B53BC92 E3A00174 B9E285D4 6A7331F9 04ABC730 1D060355
  1D0E0416 0414031B 53BC92E3 A00174B9 E285D46A 7331F904 ABC7300D 06092A86
  4886F70D 01010505 00038181 00164366 50752AA2 F76EC016 E02082A6 20F401CC
  464EF401 B4C6D625 123038F0 D78B59E1 C9C23D46 A0D2A867 C35AEFA2 8C800722
  16E5CEAC CF283B2C 17926B99 B41C4365 FCF87E7D 67A18170 2DEF6368 D3E9F656
  0619D248 BA9EC3C8 503F6846 C694562E 7D65DB82 0644804C 26575E37 072885A9
  EF04D782 0D4465D9 3C471185 86
   quit
dot11 syslog
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.91.1 10.1.91.49
ip dhcp excluded-address 10.1.91.241 10.1.91.255
ip dhcp excluded-address 192.168.91.1 192.168.91.49
ip dhcp excluded-address 192.168.91.241 192.168.91.255
ip dhcp pool phone
network 10.1.91.0 255.255.255.0
default-router 10.1.91.1
option 150 ip 10.1.91.1
ip dhcp pool data
import all
network 192.168.91.0 255.255.255.0
default-router 192.168.91.1
dns-server 8.8.8.8 8.8.4.4
no ip domain lookup
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-net5
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.91.1 port 5060
max-pool 40
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 35
time-format 24
date-format D/M/Y
create profile sync 0003339850414189
voice translation-rule 4
rule 15 /^.*$/ /4956602180/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
rule 1 /4956602180/ /398/
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile AA_Profile
translate called 2001
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC540W-FXO-K9 sn FHK1415735H
license accept end user agreement
archive
log config
  logging enable
  logging size 600
  hidekeys
username root privilege 15 secret 4 BPLnn4zPebCYELEG9US9KrGij4sS4p7fN8yjtJik5m2
controller E1 0/2/0
pri-group timeslots 1-16
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address 78.107.153.102 255.255.255.0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip verify unicast reverse-path
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
trunk-group ALL_T1E1
no cdp enable
interface Dot11Radio0/5/0
no ip address
ssid cisco-data
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.91.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.91.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 78.107.153.98
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.91.0 0.0.0.255
access-list 1 permit 192.168.91.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.91.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.91.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.91.0 0.0.0.255 any
access-list 101 deny   ip 192.168.91.0 0.0.0.255 any
access-list 101 deny   ip 78.107.153.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.91.0 0.0.0.255 any
access-list 102 deny   ip 78.107.153.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.91.0 0.0.0.255 any
access-list 103 deny   ip 78.107.153.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_15##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.91.0 0.0.0.255 any
access-list 104 deny   ip 192.168.91.0 0.0.0.255 any
access-list 104 permit udp host 8.8.8.8 eq domain any
access-list 104 permit udp host 8.8.4.4 eq domain any
access-list 104 permit icmp any host 78.107.153.102 echo-reply
access-list 104 permit icmp any host 78.107.153.102 time-exceeded
access-list 104 permit icmp any host 78.107.153.102 unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any log
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7945_7965/apps45.9-3-1ES13.sbn alias apps45.9-3-1ES13.sbn
tftp-server flash:/phones/7945_7965/cnu45.9-3-1ES13.sbn alias cnu45.9-3-1ES13.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.9-3-1ES13.sbn alias cvm45sccp.9-3-1ES13.sbn
tftp-server flash:/phones/7945_7965/dsp45.9-3-1ES13.sbn alias dsp45.9-3-1ES13.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.9-3-1ES13.sbn alias jar45sccp.9-3-1ES13.sbn
tftp-server flash:/phones/7945_7965/SCCP45.9-3-1SR2-1S.loads alias SCCP45.9-3-1SR2-1S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
cptone RU
station-id name FAX_HP1536
station-id number 401
caller-id enable
voice-port 0/0/1
cptone RU
shutdown
caller-id enable
voice-port 0/0/2
cptone RU
shutdown
caller-id enable
voice-port 0/0/3
cptone RU
shutdown
caller-id enable
voice-port 0/2/0:15
cptone RU
bearer-cap Speech
voice-port 0/1/0
trunk-group ALL_FXO
cptone RU
connection plar 201
shutdown
caller-id enable
voice-port 0/1/1
trunk-group ALL_FXO
cptone RU
connection plar 202
shutdown
caller-id enable
voice-port 0/1/2
trunk-group ALL_FXO
cptone RU
connection plar 203
shutdown
caller-id enable
voice-port 0/1/3
trunk-group ALL_FXO
cptone RU
connection plar 204
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.91.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description ?catch all dial peer for BRI/PRI?
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 398
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2003 voip
description ** cue auto attendant PSTN number **
translation-profile outgoing AA_Profile
destination-pattern 4956602180$
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 397
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 pots
direct-inward-dial
port 0/2/0:15
dial-peer voice 60 pots
trunkgroup ALL_T1E1
description **CCA*North American-10-Digit*10-Digit Local**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 9[2-9]T
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup ALL_T1E1
preference 1
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.91.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 0
service phone ehookenable 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message .
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7945 SCCP45.9-3-1SR2-1S
load 7965 SCCP45.9-3-1SR2-1S
load 521G-524G cp524g-8-1-17
time-zone 35
time-format 24
date-format dd-mm-yy
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$d0XT$oQsL/RR7PVI60rV3HUWJ4/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Jan 23 2014 18:53:58
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  296  dual-line
number 202 no-reg primary
label 202
description Vera Dikova
name Vera Dikova
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  297  dual-line
number 201 no-reg primary
label 201
description Michail Nikolaev
name Michail Nikolaev
ephone-dn  298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
ephone  5
device-security-mode none
mac-address E8ED.F3AB.F4FD
ephone-template 16
username "MN" password 123456
type 7945
button  1:297
ephone  6
mac-address C025.5C42.C991
ephone-template 16
username "VD" password 123456
type 7945
button  1:296
alias exec cca_voice_mode PBX
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Thu Jan 23 18:17:59 MSK 2014^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
121
