Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
uc500 fxo hunt groups
The default uc500 config (using cca) puts fxo ports in a hunt group and applies the hunt group to the pots dial peers.
Problem is if one fxo trunk is oos, the hunt group does not hunt around .ie unplug trunk 1, and outbound calls are busy signals. Hard to believe the hunt group can't get around a failed trunk?
Whats the point of a hunt group?
I could just put preferences on the ports directly, but default config from cca builds hunt groups when you select the north american dial plan.
Hall of Fame Super Gold
Re: uc500 fxo hunt groups
Unfortunaly that is normal behavoir. You can try playing around with voice class under trunk group, or shutdown the port when one is out of service.
ouch.
Hard to believe there's no mechanism to monitor the fxo port to remove it from the trunk group. Then again, a bad b channel in a pri will still get hit, but if the dchannel goes down the pri will fail from one controller to a second one....
Thx for the reply
As I said, there are commands in voice class cause that may facilitate that, but are poorly documented and I haven't seen so far a configuration that is guaranteed to work.
342
