UC500 phone firmware upgrade "auth fail"
Hi all,
I have a UC520 with 8.0 version installed, after de upgrade to 8.0 the phones don't upgrade the firmware, it starts the upgrade but immediately gives a "Auth Fail" in the screen, proceeding with the boot.
I haven't configured anything on phone security...
I welcome any help.
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
Re: UC500 phone firmware upgrade "auth fail"
What kind of phones?  What firmware version are you upgrading them from and to?
If you are trying to go to SCCP 8.5.3 I think you need to be at 8.5.1 or 8.5.2 first or you will get this error because of new signed firmware versions.
-- please remember to rate and mark answered helpful posts --
You will need to go under your flash and install the 8.5.2 firmware for that type of phone
So take backup of the 8.5.3 firmware and the lines in your config for 8.5.3
Then you will need to issue
For example
tftp-server flash:/phones/7941_7961/apps41.8-5-2TH1-9.sbn alias apps41.8-5-2TH1-9.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-2TH1-9.sbn alias cnu41.8-5-2TH1-9.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-2TH1-9.sbn alias cvm41sccp.8-5-2TH1-9.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-2TH1-9.sbn alias dsp41.8-5-2TH1-9.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-2TH1-9.sbn alias jar41sccp.8-5-2TH1-9.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-2S.loads alias SCCP41.8-5-2S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
ofcource have to no the old lines out which point towards the newer 8.5.3 firmware.
then you need to go to telephony-services
and do the loads
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-2S
load 7941GE SCCP41.8-5-2S
load 7961 SCCP41.8-5-2S
load 7961GE SCCP41.8-5-2S
load 7970 SCCP70.8-5-2S
load 7971 SCCP70.8-5-2S
load 521G-524G cp524g-8-1-17
Reset the phone and they should program to 8.5.2
then move the old files back and restore the old config.
That will flash the phone to the 8.5.3 version which comes with 8.0
Hope this help
Hafthor Hilmarsson CCIE - Voice #24527
For example
and do the loads
Hope this help
Hello double H,
I had the same "auth fail" problem after upgrading my UC520 from V4.2 to V8.0.4.  Reading thru your post I downloaded 8.5.2(SR1) thinking it was close enough and still have the error.  Should I go back and try 8.5.2 or is my problem maybe different?  Also, I see they have a .sgn file for download which I ignored.  What, if anything needs to be done with that file?
Thanks in advance.
Diego
I just solved this by updating the phones firmware to release 9.
I tried several 8.x versions like someone stated by all of them gave the
"auth failed", but with the 9 release it upgraded well.
Rui Cordeiro
Yes you have to upgrade to 8.5.2 the SR1 has the same "bug" issues.
You can also read about this in this case notes
https://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852SR1.html
For all SCCP firmware upgrades from firmware  release versions earlier than 8.3(3) to version 8.5(2)SR1 or greater,  you must first upgrade your firmware to version 8.5(2). Once you have  upgraded to version 8.5(2), you can upgrade your IP Phone to version  8.5(2)SR1 or later.
I didn't want to go to 9 because I am not sure if it will work with V8 of CME on UC520.  Other than fixing the auth fail issue is there anything significant about the V9 loads?
Diego
For me worked fine, nothing relevant to say about it. It works with
version 8 because I also have version 8 installed.
Rui Cordeiro
Thank you Rui.
Diego
3223
