UC500 Series question
Can UC500 be used as a total solution ( ie routing + voice ) for a remote branch ?
In other words , does routing also buit-in for this box ?
1 ACCEPTED SOLUTION
Re: UC500 Series question
sorry no it can't, if you need WAN connectivity you will need a seperate router for this
I hope this helps
I hope this helps
Silver
Hi nkariyawasam
the UC500 system has a WAN uplink (10/100 Mbps) available. and this uplink can be used to provide connectivity into the broadband infrastructure (DSL modem, existing ISR or other data network set-up).
so you have to get a seperate data network setup box.
hth
/majdi
96
