UC500 Unified Communications Manager Express T.38 Fax
Looking for help troubleshooting an issue where fax is failing. The call connects, hear fax tone, and transaction eventually fails as if it times out. Status report says either "no memory" or "low memory". The problem is intermitent - 1 out of 4 faxes will be successfully transmitted. Maintenance company switched out the fax module on the machine and problem persists.
Platform is UC520 running Advanced IP Services 15.1(4)M5. Faxes are sent through SIP provider to PSTN.  I don't believe it's a provider issue, as other clients using the same provider with no problems.  Attached is "debug ccsip messages" and "debug voice ccapi inout". I don't see any errors, but perhaps I'm overlooking something.
Any guidance is greatly appreciated!
Everyone's tags (5)
Re:UC500 Unified Communications Manager Express T.38 Fax
Can u attach the output of the following:
Show sip-ua register status
Show tech
Kevin
Sent from Cisco Technical Support Android App
If u go through the logs u received a 401 not authorized from the Telco.
Kevin
Thanks for the reply. I see what you're saying, Kevin. However, it looks to me like that is a register message. Look at line 738. It shows "200 OK" for call from fax machine to PSTN.
Am I misinterpreting the debug? Does anything else catch your eye?
Thanks again.
Can you let me know the calling/called number along with the "show run".
Kevin
Hi Kevin,
Calling number: 15554869010
Called number: 15559465226
I have attached the "show tech" for your review.  Thanks again for volunteering your time to assist.
Best regards,
Brad
Hi Brad,
Here is the analysis of the debugs.
Does the ITSP support T.38, If yes then we would need to add the following on dial-peer 1001 voip:
dial-peer voice 1 voip
  fax protocol t38 nse ls-redundancy
  fax-relay ecm disable
  fax nsf 000000
  fax-relay sg3-to-g3
Let me know how if this works.
Outgoing fax from teh UC520:
000454: Feb 11 00:52:52.260: //-1/AB8B5D8680D8/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8854FECC, Call Info(
   Calling Number=301,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20008, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Hits dial-peer 1001 pointing to the SIP-TRUNK:
000514: Feb 11 00:53:06.292: //250/AB8B5D8680D8/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x88037AD4, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=15554869010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=15559465226(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
UC520 sent a INVITE:
Sent:
INVITE sip:15559465226@register2.sip_provider.net:5060 SIP/2.0
Via: SIP/2.0/UDP 17.3.82.113:5060;branch=z9hG4bKDD3E3
To: <15559465226>
Date: Tue, 11 Feb 2014 00:53:06 GMT
Call-ID: B3E9C823-91ED11E3-80DD9CBC-F0095099@17.3.82.113
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2878037382-2448232931-2161679548-4027142297
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1392079986
Contact: <15554869010>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 282
v=0
o=CiscoSystemsSIP-GW-UserAgent 6936 8197 IN IP4 17.3.82.113
s=SIP Call
c=IN IP4 17.3.82.113
t=0 0
m=audio 18132 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
We recieve a 100 Trying followed by a "407 Proxy Authentication Required":
000526: Feb 11 00:53:06.468: //251/AB8B5D8680D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 17.3.82.113:5060;received=17.3.82.113;rport=64146;branch=z9hG4bKDD3E3
To: <15559465226>
CSeq: 101 INVITE
Server: ccnq3 complete proxy
Content-Length: 0
000527: Feb 11 00:53:06.480: //251/AB8B5D8680D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
To: <15559465226>;tag=c97b4d1cb1f3d0da549e06a8d482ef63.f388
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="register2.sip_provider.net", nonce="52f974ae8872af8578709c17a4a591aed5f0f363"
Content-Length: 0
We do sent a INVITE again, where media is Media is Negotiated in "183 Session Progress":
Sent:
Via: SIP/2.0/UDP 17.3.82.113:5060;branch=z9hG4bKDEECD
To: <15559465226>
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="15554869010",realm="register2.sip_provider.net",uri="sip:15559465226@register2.sip_provider.net:5060",response="9eb5312d98a32a7ea1c3beae85fb7e73",nonce="52f974ae8872af8578709c17a4a591aed5f0f363",algorithm=md5
Content-Length: 282
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
000530: Feb 11 00:53:06.552: //251/AB8B5D8680D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 17.3.82.113:5060;received=17.3.82.113;rport=64146;branch=z9hG4bKDEECD
To: <15559465226>
CSeq: 102 INVITE
Content-Length: 0
000531: Feb 11 00:53:09.908: //251/AB8B5D8680D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 17.3.82.113:5060;rport=64146;received=17.3.82.113;branch=z9hG4bKDEECD
Record-Route: <4.53.160.137>
To: <15559465226>;tag=1aS4cea3gD4BH
CSeq: 102 INVITE
Contact: <15559465226>
User-Agent: ccnq3 nomedia egress-usa
Accept: application/sdp
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REFER, NOTIFY
Supported: timer, precondition, path, replaces
Allow-Events: talk, hold, conference, refer
Content-Length: 223
X-CCNQ3-MediaProxy: on
v=0
o=Sonus_UAC 6851 31982 IN IP4 66.62.60.234
s=SIP Media Capabilities
c=IN IP4 4.53.160.137
t=0 0
m=audio 41546 RTP/AVP 0 101
a=fmtp:101 0-15
a=maxptime:20
Rate the post accordingly.
Kevin
Hi Kevin,
I just want to make sure this won't have any negative impact on regular voice calls using this dial peer.  Is it okay to have both fax and voice on the same dial peer?
Brad
T.38 will only be used when a CED tone is detected. Normal voice calls are not affected.
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
Keven suggested this:
  fax nsf 000000
  fax-relay sg3-to-g3
In general I would advise not to use NSE based T.38 as it is a Cisco proprietary implementation. (Not even supported by eg Cisco ATA187.)
Instead try standard based aka protocol based T.38 by relacing the the fax protocol command with
"fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw"
Best regards
Thank you both for your suggestions.  I have implemented and will allow a few days for the customer to test.  The value of the support community cannot be overstated.  It's as good, if not better, than TAC.
Best regards,
Brad
Hi Brad,
This wont affect your Voice calls, because once the Voice calls establish then only  T.38 (FAXING) or the switchover with take place.
I have given a example  of the T.38 call flow along with  the switchover in the diagram below:
Kindly rate the post accordingly.
Kevin
Thank you, Kevin.  I think this did the trick.  Do I also need to do this for the inbound dial peer?
Thanks Brad,
Thats good news, Kindly rate the post accordingly.
Kevin
464
