Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
UC500 vs CME
Does anyone have information on where these two products are most suited? from what I can see they have very similar features
for example if I have a site with 20 phones a BRI connection to the pstn and voicemail, which one is best , which is cheaper?
thanks
VIP Super Bronze
Re: UC500 vs CME
The UC500 series product is a bundle of other products cramed into a single chassis. CME is one of these features as is CUE, VPN, firewall, and PSTN gateway functionality. I won't speak to pricing here; this is something that you should work out with your Cisco partner/reseller.
The main deciding factor should be scalability. What will your needs be in the next X years that you expect the equipment to last? Craming everything into one box tends to impose lower scalability limits.
Re: UC500 vs CME
Jonathan makes good points.  Particularly about scalability.  If you are looking at a single small office or a handful of small offices I think either product would be OK and basically equivalent (compare prices).
The other consideration is support.  UC500 is not handled by regular TAC and SmartNet.  They have their own small business support group.
-- please remember to rate and mark answered helpful posts --
772
