UC500
Do we need specific licenses for what type of phones we can use with UC500, like 7940, 7960 and so on, or any phone type is supported and the general license covers everything.
For example:
UC520W-8U-4FXO-K9 supports 8 phones, can these phones be any type?
Cheers
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: UC500
Hi Hadi,
First off, you are most welcome :)
Here are some related links. You will find the SBCS - Wiki extremely useful;
Cisco Smart Business Communications System Teleworker Setup
http://www.cisco.com/en/US/docs/voice_ip_comm/sbcs/hardware/quick/guide/uc5_tele.html
SBCS:Documentation - Cisco Smart Business Communication Systems - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Documentation_-_Cisco_Smart_Business_Communication_Systems
Hope this helps!
Rob
Re: UC500
Hi Hadi,
As far as I know you don't require any specific license for the type of phones you are going to use.
Please wait for confirmation from other members, since I am not 100% sure and never ordered UC500.
-> Sushil
Re: UC500
Hi Hadi,
My friend Sushil is most correct :) (+5 points buddy!)
When you order a pre-configured UCS 5XX is does come with all applicable Licensing (including IP Phone licenses).
Have a look at this as well;
Various fixed configurations are offered, eliminating the guesswork from configuration.
Each configuration is equipped with the appropriate number of feature licenses for call processing, voicemail, and Cisco Unified IP phones, simplifying the product structure.
For example;
UC520-8U-2BRI-K9
8 User configuration with 2 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion
Feature licenses for call control, voicemail and **Cisco Unified IP Phones
Or
UC520W-8U-4FXO-K9
8 User configuration with 4 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion, Integrated Wi-Fi Access Point
From this good UCS 500 doc;
http://www.cisco.com/en/US/products/ps7293/products_data_sheet0900aecd8061fb06.html
Hope this helps!
Rob
Re: UC500
Rob nice compilation to support my thought :)
Re: UC500
Thanks guys and appreciate your help, I have another question though. What is a teleworker? example the 8 and 16 user support version of UC500 support 2 teleworkers. Is this remote users with soft phones? I am a bit confused here as to whether it's the number of soft phone support or something else.
Hadi
Re: UC500
Hi Hadi,
Hope this helps!
Rob
Re: UC500
Thanks Rob, your help is greatly appreciated.
170
