UC520 2xBRI basic setup instruction
I'm new to Cisco voice.
I have a UC520 2xBRI (seperate lines with 2 blocks of 4 numbers).
Can someone give me the basic steps
to get BRI working?
I only need a simple setup.
Number forward to hunt group for general use (office number) and direct forwaring to specific telephones.
I see the line light up on call but I do not understand how to handle incoming calls.
Kind regards
Vincent
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: UC520 2xBRI basic setup instruction
Sure. Let's assume you do not use any digit as access for external calls (thing that sually users like very much ebcuae it's like calling from home:
dial-peer voice 58 pots
desc international
destination-pattern 001.....T
prefix 001
trunkgroup bri
dial-peer voice xxx pots
desc cellphones
destination-pattern 06........
trunkgroup bri
desc national
destination-pattern 0[1-9]........
prefix 0
trunkgroup bri
desc emergency
destinaion-pattern 112
prefix 112
trunkgroup bri
Then you can remove the ununsed DPs.
Add a translation-profile to the trunk group, for incoming, and recall teh following rule against calling number:
voice translation-rule 300
rule 1 // /0/ type national national
rule 2 // /00/ type international international
One way is dialplan-pattern under telephony service. But since you just have eight numbers, it may not be worth that.
So I suggest trunk-group and translation-profiles. xxxx below is the called number, check it with "debug isdn 1931" and "term mon". eee is the phone extension of ephone-hunt pilot.
It looks complicated, once you get sounde of it, it's very flexible.
int bri 0/0/0
trunk-group bri
int bri 0/0/1
trunk-group bri
trunk group bri
translation-profile incoming makedid
voice translation-profile makedid
translate called 100
voice translation-rule 100
rule 1 /xxxx/ /eee/
rune 2 ...
I must have had my brain switched off when answering above.
There is a much simpler way. Assign the phone number, as received from telco, as secondary under ephone-dn. Same for ephone-hunt.
Thank you, I understand your message, but
I have trouble setting up the dial-plan (I think). The configuration assistant gives an USA dial plan while I need to configure an Dutch dial plan.
I think this is te reason things are not working. I can not find however a proper example of a Dutch dial plan config..?
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/dpdeploy.htm#wp1031584
I've found this site, but do not know how to implement this.
Hi, forget dialplan pattern. Just set the secondary numbers, and all will work fine.
Next issue, is what number do you want to be seen by a called person when you call out ?
caln you call out at all ?
Thanks again, I can not call inbound or outbound. Number unreachable when calling. I do see however light up BRI lights on the UC520. (I'm newbie to Cisco voice, sorry)
I'm using the default factory config right now, no modifications except for the secondary number as explained.
Likely tei issue.
interface bri0/0/0
isdn static-tei 0
same for other interface.
Thanks again, it does not work, please see the relevant config below.
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
ephone-dn 10 dual-line
number 201 secondary <10digitnumber> no-reg primary
label 201
description User1
name User1 User1
call-forward busy 333
call-forward noan 333 timeout 10
Hi, which exact IOS are you using? Do you have access to downloads to upgrade to 12.4(11)XW5 if that is not what you have already ?
I'm stuck now, I used the ZIP file to upgrade to XW5 which the config assistent told me was successfull.
After te reload the device is dead. I can only use the console cable. IP traffic (switch) isn't working anymore?
You may have got interfaces in shutdown. send config.
Hello, here is the config (after upgrade)
Kind regards,
Oh, one of these sdm configurations. What is not working, do the phones register? Can you ping something ?
Hello again,
It's a cisco config assistant factory default config indeed.
The phones register, and all internal call functions are working.
I've upgraded to XW6 (latest). However, no luck. KPN the telco tells te calling party, number not in use.
ISDN debug shows the message: followingUnallocated/unassigned number
Feb 17 14:48:12.395: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Feb 17 14:48:12.467: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x0E
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '6********'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2********'
Feb 17 14:48:12.475: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x8E
Channel ID i = 0x89
Exclusive, B1
Feb 17 14:48:12.503: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x8E
Cause i = 0x8081 - Unallocated/unassigned number
Feb 17 14:48:12.555: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x0E
Feb 17 14:48:12.559: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8E
Feb 17 14:48:22.759: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Feb 17 14:48
Hello again,
Incoming calls are working now.
After configuring the correct DID translation.
Last but not least, can you tell how to set the number seen by a called person when I call out?
Kind regards,
Hi, if you want them to see your extension calling number, you can set again a translation rule. Looking at the configuration, have you understood now how it works ? Also, if you have two bris active, you need trunk group. The config assistant isn't able to do these things.
I created the trunk group using command line.
This also works.
But I still have troubles with the dial plan. (In the CCA is only North American plan available).
I changed some values and can now call
regional numbers as follows:
Our number starts with 024 and then 7 digits
I can call all other numbers that start with 024 in our region. I can not call e.g. Amsterdam starting with 020
Also I can not call mobile numbers which start with 06 and then 8 digits
Can you explain me (perhaps small example) how to change this correctly in command line?
Your help is much appreciated.
Kind regards.
desc international
prefix 001
trunkgroup bri
desc cellphones
trunkgroup bri
desc national
prefix 0
trunkgroup bri
desc emergency
prefix 112
trunkgroup bri
Thanks, this works!!
One last question, incoming callerID is displayed without the 0 making it not possible to return missed calls (wrong number obviously) How do I correct this?
Kind regards,
How do I select the default outbound ISDN number. isdn calling-number does not work.
The customer wants to use the 3th number of the block of 4 numbers. The line defaults to the first number on outbound calling.
You can use either a translation rule at trunk-group level, or under each interface bri
isdn calling-number XXX
Note possibly you have to specify it without the 0.
In any case check what you're sending with "debug isdn q931" and "term mon".
Hello, I understand your config but somehow I can not get it working, I did this
voice translation-rule 4
rule 2 // /00/ type international national
voice translation-profile Add_Zero
translate called 4
dial-peer voice 50 pots
trunkgroup ISDN-LINES
description ** incoming dial peer **
translation-profile incoming Add_Zero
incoming called-number .%
direct-inward-dial
prefix 0
dial-peer voice 51 pots
direct-inward-dial
prefix 0
This does not add zero's
Kind regards.
Apparently I did not understand it,
I configured the profile on the ISDN-Trunk and now it's working, so please discard the config above.
Thank you very much for the excellent instructions!
My vlans were damaged in some way?
I have added a temp vlan using command line
which gives me access again to the unit.
I will try to update to the latest version (I see 15 feb 08 is the latest) first.
410
