Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
UC520 and 7961 phone local fails to update
I downloaded the correct locale (NL) for my 7941 and 7961 phones.
The 7941 updates correctly, the 7961 fails and remains US. How can I troubleshoot this?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: UC520 and 7961 phone local fails to update
Look, these files are not available:
Mar 6 11:27:24.581: TFTP: Looking for Dutch_Netherlands/mk-sccp.jar
Mar 6 11:27:24.865: TFTP: Looking for United_States/g3-tones.xml
When the are, you see "Finished" after the tftp transfer completes.
Use the alias option to specify correctly the files that phone wants.
Strange because they are really the same phone. Anyway, enable "debug tftp events" and "term mon". Do a factory reset on the phone, power off, power on with # pressed, press in sequence 123456789*0#. Make sure you have term61.default.loads in the router when you do this.
Hello here's the log. As far as I can see all the needed files are available. What is going wrong?
Mar 6 11:27:23.377: TFTP: Looking for CTLSEP001E138CD377.tlv
Mar 6 11:27:23.533: TFTP: Looking for SEP001E138CD377.cnf.xml
Mar 6 11:27:23.609: TFTP: Opened flash:/its/XMLDefault7961.cnf.xml, fd 10, siz
1222 for process 172
Mar 6 11:27:23.613: TFTP: Finished flash:/its/XMLDefault7961.cnf.xml, time 00:
0:00 for process 172
Mar 6 11:27:25.137: %IPPHONE-6-REG_ALARM: 25: Name=SEP001E138CD377 Load= 7.0(3
0S) Last=Initialized
Mar 6 11:27:25.269: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-5:SEP001E138CD377 I
:10.1.1.13 Socket:4 DeviceType:Phone has unregistered abnormally.
Mar 6 11:27:25.269: %IPPHONE-6-REGISTER: ephone-5:SEP001E138CD377 IP:10.1.1.13
Socket:3 DeviceType:Phone has registered.
157
