Community Member
UC520 and T1/PRI Card
hello,
I have a UC520 with an empty slot I was wondering if I could put a VWIC2-1MFT-T1/E1 on that slot, I've been trying to find the compatibility for the UC520 and this card but i can't find it please let me know
thanks
1 ACCEPTED SOLUTION
Re: UC520 and T1/PRI Card
Modular Support
Table 6 lists available modules and interface cards supported in the open slot.
Table 6. Modules and Interface Cards Supported in the Open Slot
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/product_data_sheet0900aecd8061fb06.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Gold
Yes, you can do that.
Modular Support
java
java
834
