UC520 as h323 Gateway and CME simultaneously
I would like to know whether I can configure UC520 as h323 gateway for CallManager and at the same time I install CME on it ?
If possible, how is the connection betwen CUCM and CME ?
  • IP Telephony
Hall of Fame Super Gold
Re: UC520 as h323 Gateway and CME simultaneously
Yes, it is no problem.
However since the datasheet says CUCM is not supported, the TAC will not support you on that aspect.
That is correct. TAC will not support this type of configuration. All you need to do to accomplish is set the UC520 up as an H323 gateway in CUCM and configure your voip dialpeers on your UC520 to point to the CUCM.
Thanks for the answer.
For example I have this scenario :
UC520 with CUE (CME license)
let say I will forward a DN on CUCM to a virtual DN on CME then all the calls to the Virtuan DN on CME will be forwarded to VM (CUE)
is it possible ?
How is the configuration ?
ephone-dn xx
call-forward all
However if you're just trying to integrate CUE to CUCME, just do that directly.
How is the connection between CCM and CUCME if i want to use the UC520 as h323 gateway and CUCME simultaneously ?
I cannot add another trunk with UC520 IP Address since it's already configured as h323 gateway
Appreaciate your help
As H.323 GW is enough, then you configure some route pattern to use it.
565
