UC520 BRI Connection
I have a new single site setup using UC520. 2 BRI ports are connecting to PSTN. I cannot get BRI work. 'debug isdn q931' shows calls are rejected even if when no calls are made. Please help me understand the debug messages. Debugs are attached. Configurations are as follows:
relavant configurations: ephone-dn are numbered from 1000--1009. 111 is the local emergency number
trunk group PSTN_OUT
description All Analogue PSTN Interfaces
translation-profile outgoing STRIP_1_OUTGOING
voice translation-rule 8000
rule 1 /^111$/ /111/
rule 2 /^1/ //
voice translation-rule 8001
rule 1 /^.*\(..\)$/ /10\1/
voice translation-profile DID_TO_EXT
translate called 8001
voice translation-profile STRIP_1_OUTGOING
translate calling 1111
translate called 8000
interface BRI0/1/0
no ip address
no logging event link-status
isdn switch-type basic-5ess
isdn timer T321 0
isdn point-to-point-setup
isdn incoming-voice voice
isdn map address .* plan national type unknown
isdn send-alerting
isdn sending-complete
trunk-group PSTN_OUT
interface BRI0/1/1
no ip address
isdn timer T321 0
isdn send-alerting
voice-port 0/1/0
translation-profile incoming DID_TO_EXT
output attenuation 3
compand-type a-law
cptone NZ
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone NZ
bearer-cap Speech
dial-peer voice 50 pots
destination-pattern .T
direct-inward-dial
port 0/1/0
no sip-register
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
no sip-register
Thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: UC520 BRI Connection
Hi, it is normal that layer 1 and 2 go down after a timeout. Router or switch will reestablish them as soon there's an active call. Also, which image are you using? You should have XW6 for the UC520.
For the extensions, you can either use an incoming rule like
rule 1 // /1/
or
dialplan-pattern 1 pattern ... extension-length 4 extension-pattern 1...
can you send output from debug isdn q931?
Hi Kenneth,
It is in the attachment.
Thanks.
please configure "isdn static-tei 0" under bri interfaces. Then you can use the trunk-group referencing it instead of port under DP.
Then you can optimize the translation-rules if needed, an alternative is to use "dialplan-pattern" under telephony-service.
In any case when you have rules under trunk group, you don;t need them under voice-port.
Note you don't need:
isdn timer T321 0
isdn send-alerting
It is getting better, but no successful calls yet.
New debug messages are attached. Please advise the next step.
Thanks.
I had not seen catched that before, for outgoing, please configure isdn switchtype basic-net3.
For incoming, how do you extensions numbers looks like ?
When I change the switch type to basic-net3, bri interface layer 2 and 3 are not up. I am using the only type that can bring up all layer 3 on the interface.
Extention number are 1000, 1002,..., 1021.
rule 1 // /1/
or
You are great!
It starts working now.
Millions of thanks.
Thanks for the nice rating and good luck!
333
