UC520 CUE IP setup
tato386
Level 6
Level 6
Why is it that the default UC520 setup uses a /30 subnet for the CUE configuration? Can I do without that and simply assign an IP to CUE that is the same as my voice VLAN?
Diego
paolo bevilacqua
The cue must be accessed via the service-engine interface. If you want to give it an address off router LAN, you can use an host route to it. This technique is described in the configuration manual.
