Community Member
UC520 - Display free lines on phones?
Hello, I have a UC520 with 2 analog lines going in and about 10 users with 7941s and 7912s. On their old PBX system they had 2 little red lights on each phone that lit-up whenever a line was busy.
Now, there doesnt seem to be a way to display if their two outgoing lines are busy... SO the only way to find out is by dialing 9-xxx-555-xxxx and then hearing a busy tone and trying a bit later when there's a free line...
Any possible way to display the 2 free lines on a 7941 screen or maybe a service someone created to see when the 2 analog lines are busy?
I think the best option would be to tell the customer to buy a 3rd or 4th line for an extra 30$/month, but they just want me to double-check.
Thanks!
Cisco UC520-16U-4FXO-K9
UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW5, RELEASE SOFTWARE (fc1)
Hall of Fame Super Gold
Re: UC520 - Display free lines on phones?
Hi, in the admin guide , check "trunk" command under ephone-dn, with the option to monitor FXO port. Note, when you configure like that, all calls made from that DN will have trunk digits prepended to dialed digits, the consequence is that you need to configure additional button for internal calls. In summary, is up to you to try first, show to customer, and find a configuration that they like.
Community Member
Thank you for your help, but I am having trouble getting this administration guide on the website... I get lost in all these pages! :-O
I know, it's large book. Try the way I do, download .pdf and use the search function. It's there, you just have to locate it.
Hey Paolo, is this the part you're referring to??
SCCP: Configuring Trunk Lines for a Key System
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1036976
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
145
