10-14-2013 08:06 AM - edited 03-16-2019 07:52 PM
We have UC520 with FXO card, and have a problem when we point the inbound call to the Cisco Unity Express Auto Attendant, the problem is if the PSTN caller disconnect, the FXO remain off-hook for along time, and if the PSTN caller dial an extension and then disconnect the phone remain ringing for a long time.
but if we point the inbound call an extention, there is no problem and the phone stop ring when the PSTN caller disconnect.
below is the voice-port, and CUE dial-peer configuration:
voice-port 0/1/2
translate calling 3
compand-type a-law
cptone NL
timeouts interdigit 4
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 500
connection plar 489
impedance complex2
description LandLine 5105586
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
voice-port 0/1/3
translate calling 3
supervisory disconnect dualtone mid-call
compand-type a-law
cptone NL
connection plar 489
impedance complex2
description LandLine 5105388
caller-id enable
dial-peer voice 499 voip
description VoiceMail
destination-pattern 498
media flow-around
session protocol sipv2
session target ipv4:10.1.10.2
dtmf-relay sip-notify
codec g711ulaw
no vad
so what we can do?
10-14-2013 10:58 AM
You need to configure custom disconnect cptone specifi for country/network.
10-16-2013 06:32 AM
Ok. i will try the custom disconnect cptone, but why the current configuration work when the inbound is pointed to a phone and not work when the inbound pointed to the auto attendant.
10-17-2013 04:16 AM
Should work in both cases, somethign si not configured correctlu if it doesn;t.
10-20-2013 12:36 AM
I was configure custom disconnect tone refer to this site:
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
And the tone is in the attachment, and the custom disconnect tone configuration like below:
voice class custom-cptone Disconnect
dualtone disconnect
frequency 420 420
cadence 251 255 245 250 249 250 250 250
and the port configuration was like below:
voice-port 0/1/2
supervisory custom-cptone Disconnect
cptone NL
connection plar 334
impedance complex2
caller-id enable
but it was not working and the phone still ringing after the PSTN caller disconnect.
but i was read about "dualtone-detect-params", and i was add the below command and i do not understand it, but it was solve hte problem:
voice class dualtone-detect-params 1
freq-max-deviation 20
cadence-variation 50
so what it is and how to determine this parameters.
10-20-2013 12:51 AM
Hi Mohammed,
kindly find the below thread. it will help you
https://supportforums.cisco.com/message/3883674#3883674
if you can't solve the disconnect signal, I think you need to ping the TAC
Anas
please rate all helpful posts
10-20-2013 07:06 AM
For your Q
That is because AA is play a continous wav file which won't disconnect the fxo
a phone won't send a continous stream after finishing so the fxo could disconnect the port
If the customer cp tone not working. Contact your telco to subscribe reverse polarity feature. It will do the task
Haitham
10-20-2013 08:48 AM
Hello Mohammed,
Best thing you could do is to run a debug on both scenarios to see why when it's answered by an IP phone the call is disconnected and why when is answered by CUE is not disconnected.
I would recommend the following debugs to check if you are receiving call disconnect stimulous from the TELCO.
Router#debug vpm port 0/0/0
Router#debug vpm signal
10-20-2013 11:08 AM
The configuration is like below:
voice class custom-cptone IRIS
dualtone disconnect
frequency 420 420
voice-port 0/1/2
supervisory custom-cptone IRIS
supervisory dualtone-detect-params 1
no battery-reversal
input gain -3
output attenuation -3
compand-type a-law
cptone NL
timeouts initial 5
timeouts interdigit 3
timeouts call-disconnect 3
timeouts ringing 5
timing guard-out 300
timing sup-disconnect 50
connection plar opx 498
impedance complex2
caller-id enable
the current situation is when inbound caller disconnect, the FXO return to "on-hook" immediately regardless where it point, but the problem now with the outbound call, it is disconnect after the second disgit, and when i remove the "timeouts wait-release 5" the outbound success and the inbound take 15 - 2- sec to disconnect after PSTN caller disconncet.
so what can i do?
10-21-2013 08:14 PM
This sounds like a FXO disconnection probem indeed. The problem here is that the FXO is not receving any disconnect signal, perhaps a Disconnect Tone that the Router sometimes understand and sometimes it doesn't.
It will be necesary to capture debugs on the different scenarios with detailed timestamps to confirm the behavior you described.
If the problem is the disconnect tone, it's neccesary a PCM capture, so you can tune the Custom CP tone configured under the voice-port.
Can you ask your Carrier to use Battery-Reversal or a different suppervisory disconnect?
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
10-21-2013 09:21 PM
Mohammed,
Please provide the debugs requested previously.
