UC520 + FXS Analog phones : Conference / Transfers etc
The UC520 has the option of having FXS ports ( as does CCME).
I was wondering how features like transfers / conferences and others that are normally done using "softkeys" can be achieved on FXS phones ?
I believe the ATA's have feature codes that convert them to SCCP, but how does this work in a pure FXS environment ?
I have come across references to STCAPP, but all the examples seem to involve an external Voice Gateway (VG224).
Can STCAPP be run on the SAME gateway that is also running CCME ???
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: UC520 + FXS Analog phones : Conference / Transfers etc
Yes, absolutely. I think you know the url already but there it is again:
http://cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html
Also I understand that when you use the "configuration assistant" it will put ports in sccp mode.
1 REPLY
127
