UC520 Inbound Caller ID
Hi All,
We have a UC520 system installed, it works fine in and outbound calls. All outbound calls show our primary number as the CID, however right now incoming calls only show the calling number.
When I added this line to my PRI port:
interface Serial0/3/0:23
no isdn supp-service name calling
incoming caller ID now shows correctly, however now I am unable to make out bound calls.
I think these are all of the rules for outbound but am not sure why.
Below is what I assume are the pieces of configuration needed ?
voice translation-rule 1111
rule 1 /.*/ /xxxxxxxxxx/
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
dial-peer voice 151 pots
corlist outgoing call-local
description ** T1 pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]......
port 0/3/0:23
forward-digits 7
no sip-register
dial-peer voice 152 pots
corlist outgoing call-domestic
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/3/0:23
prefix 1
no sip-register
dial-peer voice 154 pots
description ** T1 pots dial-peer **-Emergency dial-peer
preference 5
destination-pattern 9911
port 0/3/0:23
forward-digits 3
no sip-register
dial-peer voice 155 pots
preference 5
destination-pattern 911
port 0/3/0:23
forward-digits 3
no sip-register
dial-peer voice 156 pots
preference 5
destination-pattern 9[2-9]11
port 0/3/0:23
forward-digits 3
no sip-register
Thank You.
Gary
Hall of Fame Super Gold
Re: UC520 Inbound Caller ID
Take "debug isdn q931" with "term mon" it the various situations, that will clarify what's going on.
Ok, I get this reject code - guess this is the reason.
268910: Apr 24 01:43:10.264: ISDN Se0/3/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x820C
Cause i = 0x82B2 - Requested facility not subscribed
Ok, but one should check what exactly is the facility and why the clid is not correct when facility is not used.
Morning,
I have attached the fail log - I tried working my way through it and comparing it against a connection when I don't use the "isdn supp-service name calling" line - wasn't sure what I should be looking for.
Thanks for your help.
Please take the traces with "debug isdn q931" ad indicated above, and nothing else.
515
