Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
UC520 Incoming Calls
We have configured and began testing with our UC520. US style T1 PRI: Outbound calls work fine but no incoming calls to our trigger number are not being answered by the AutoAttendant, incoming callers get dial tone - they are able to then dial the AA or an extension fine.
Calls to any DID number are also being answered but they also get dial tone - I assume I have an issue with our Dial Peers but not sure where to look.
thanks
Re: UC520 Incoming Calls
Can you post your config here?
Here it is, minus the ephones
Got it fixed - the telco was stripping off the first 6 digits - changed my rules and all works fine.
142
