UC520 not recognising * Keypress for outbound call
Stuart Taylor
Hello All,
Wonder if you can help me at all - we've just setup a 2nd UC Box which I've moved our SIP trunks over to from my 1st UC.
I've taken a copy of the configuration and inbound calls are coming in without any problems,  BUT on my first UC I had three outbound dialing codes, *01, *02 and *03 which basically meant their CLID was written within three different numbers etc etc..
BUT on the 2nd UC when I try to make an outbound call by entered *01 for example I get an engaged tone after pressing *01,  I've taken a look at the dialpeer debugs and it seemingly doesn't pickup the * keypress.
On the 1st UC when I've tested it the same way it picks up * 0 1 with each keypress.
The Locales are all set to UK and I really have run out of ideas - - can anyone help?
6 Replies 6
Stuart Taylor
I should add that when I've changed it to dialing a 7 for an outside line it works without any problem but i really need to stick to my *01,*02 and *03 codes..
here is an output of the dialpeer debug - I've dialed *01 but as you can only see it says 'Called Number=1'
060082: May  6 23:22:46.146: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Calling Number=620, Called Number=, Voice-Interface=0x892A24F0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,   Peer Info Type=DIALPEER_INFO_SPEECH
060083: May  6 23:22:46.146: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20018
060084: May  6 23:22:46.146: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
060085: May  6 23:22:48.879: //-1/38CFD46B8113/DPM/dpMatchPeersCore:   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
060086: May  6 23:22:48.879: //-1/38CFD46B8113/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=1
060087: May  6 23:22:48.879: //-1/38CFD46B8113/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
060088: May  6 23:22:48.879: //-1/38CFD46B8113/DPM/dpMatchSafModulePlugin:   dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=-1
060089: May  6 23:22:48.879: //-1/38CFD46B8113/DPM/dpMatchPeersMoreArg:   Result=NO_MATCH(-1)
So do you have *01 *02 and *03 as secondary-dial tone?
Can you send the show run and debug voip ccapi inout when trying to dial any of those?
-Luis A.
Here are my debug voip ccapi inout results when dialing *01
000265: May  7 00:54:03.368: //-1/F97CEA7C804C/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=620
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
000266: May  7 00:54:03.368: //-1/F97CEA7C804C/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x88E22328, Call Info(
   Calling Number=620,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20014, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
000267: May  7 00:54:03.368: //-1/F97CEA7C804C/CCAPI/ccCheckClipClir:
   In: Calling Number=620(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000268: May  7 00:54:03.368: //-1/F97CEA7C804C/CCAPI/ccCheckClipClir:
   Out: Calling Number=620(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000269: May  7 00:54:03.368: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000270: May  7 00:54:03.368: :cc_get_feature_vsa malloc success
000271: May  7 00:54:03.368: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000272: May  7 00:54:03.368:  cc_get_feature_vsa count is 3
000273: May  7 00:54:03.368: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000274: May  7 00:54:03.368: :FEATURE_VSA attributes are: feature_name:0,feature_time:2248654520,feature_id:17
000275: May  7 00:54:03.368: //38/F97CEA7C804C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=620(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
000276: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/cc_process_call_setup_ind:
   Event=0x88052920
000277: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccCallSetContext:
   Context=0x8A4A1738
000278: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 38 with tag 20014 to app "_ManagedAppProcess_Default"
000279: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccCallSetupAck:
   Call Id=38
000280: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
000281: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=38
000282: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
000283: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
000284: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccCallReportDigits:
   (callID=0x26, digit_event=0x1, enable=TRUE, consume=FALSE)
000285: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=38
000286: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x88E22328, callID=0x26, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
000287: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x88E22328, Call Id=38
000288: May  7 00:54:03.372: //38/F97CEA7C804C/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
000289: May  7 00:54:04.312: //38/F97CEA7C804C/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=38, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x81A38, Rtp Expiration=0x0
000290: May  7 00:54:04.312: //38/F97CEA7C804C/CCAPI/cc_api_call_digit_end:
   Source Call Id=38, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
000291: May  7 00:54:04.312: //38/F97CEA7C804C/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
000292: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/ccCallReportDigits:
   (callID=0x26, digit_event=0x0, enable=FALSE, consume=FALSE)
000293: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/ccCallReportDigits:
000294: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x88E22328, callID=0x26, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
000295: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/cc_api_call_report_digits_done:
000296: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/cc_api_call_report_digits_done:
000297: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000298: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
000299: May  7 00:54:04.316: //38/F97CEA7C804C/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
000300: May  7 00:54:07.284: //38/F97CEA7C804C/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x88E22328, Tag=0x0, Call Id=38,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
000301: May  7 00:54:07.284: //38/F97CEA7C804C/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
000302: May  7 00:54:07.284: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000303: May  7 00:54:07.284: :cc_free_feature_vsa freeing 8607BEB0
000304: May  7 00:54:07.284: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000305: May  7 00:54:07.284:  vsacount in free is 2
Below is my running config - taken private parts out - - - as I have people in my offices tomorrow running from this phone system I've altered the standard 9XXXXXXXX so it goes out through the SIP  - - - and that's fine - - - but as I said earlier the *01, *02 and *03 codes basically rewrites our CLID so it matches the office the person has called from...
Last configuration change at 01:56:21 GMT Mon May 7 2012 by TAPAdmin
NVRAM config last updated at 01:45:29 GMT Mon May 7 2012 by TAPAdmin
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot-end-marker
logging buffered 16384
enable secret 5 $1$lhsP$SOTRd1VrcKNIMmgX7ufY50
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone GMT 0 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-select 1 BRI0/1/0
network-clock-select 2 BRI0/1/1
crypto pki trustpoint TP-self-signed-3876808388
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3876808388
revocation-check none
crypto pki certificate chain TP-self-signed-3876808388
certificate self-signed 01
  30820251 308201BA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33383736 38303833 3838301E 170D3132 30343330 30393333
  32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38373638
  30383338 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009AC8 C4F09A94 841AB7EA 95D4A821 C8F2ABB5 A58E69EA 422206FB 6AA3A138
  FB33A003 7AD3CB40 4BD51349 23D4CF43 64A493D5 C6DC7C84 D871F899 4B7AFFD1
  98EF83A4 E76F8F1E 19C3050A 2D8F3ABC 11FDF7BA 611D3AFA 98BDA065 7E93C433
  06144A8B A525FD3B 1AD8183D DB422335 945B12CC 9BDE31D4 6F2A86C4 794FCC1E
  240D0203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603
  551D1104 1D301B82 19554335 32302E74 65616368 65726163 74697665 2E6C6F63
  616C301F 0603551D 23041830 1680144B 9F647BA4 2BDA4AA8 4558C567 C6088895
  9013A630 1D060355 1D0E0416 04144B9F 647BA42B DA4AA845 58C567C6 08889590
  13A6300D 06092A86 4886F70D 01010405 00038181 001094E9 2E1BFD5F 8A182114
  2A243C65 617492E4 89D5E96B B3A15C1F 052A36C2 3D07C6E7 2E6B0EA9 5FFDD442
  3BCDF258 3CEDA589 CC404856 1111ACE3 F91202CA 4B35B2D3 BDA5CA8F D00359EE
  678BDC12 D49E4F1D 4785F2F0 0B5DF851 1E43743B 0E63354A FEFEEB65 D872CD3B
  9270ED14 F758944E 84434660 D56087C1 5B3522C7 61
            quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip domain name teacheractive.local
ip name-server 192.168.0.4
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type basic-net3
trunk group ALL_BRI
hunt-scheme longest-idle
translation-profile outgoing PROFILE_ALL_BRI
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  bind control source-interface Vlan1
  bind media source-interface Vlan1
  no update-callerid
  sip-profiles 100
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class sip-profiles 100
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice register global
mode cme
source-address 192.168.0.248 port 5060
voice hunt-group 1 parallel
final 101
list 402,403,404,405
timeout 10
pilot 499
voice hunt-group 2 parallel
final 101
list 502,503,504
timeout 10
pilot 498
voice hunt-group 3 parallel
final 101
list 601,602,603,604
timeout 10
pilot 497
voice translation-rule 4
rule 15 // //
voice translation-rule 70
rule 1 /^2\(..\)$/ /\1/
voice translation-rule 72
rule 1 /^72\(...\)$/ /\1/
voice translation-rule 199
rule 1 /^0114XXXXXXX/ /*01 -> Forwards to mobile out of hours - otherwise goes to blast group/
rule 2 /^0161XXXXXXX/ /*02 -> Forwards to mobile out of hours - otherwise goes to blast group/
rule 3 /^0192XXXXXXX/ /*03 -> Forwards to mobile out of hours - otherwise goes to blast group/
voice translation-rule 200
rule 1 /^\*0[1-3]/ //
voice translation-rule 201
rule 1 /^.*/ /114XXXXXXX/
voice translation-rule 202
rule 1 /^.*/ /161XXXXXXX/
voice translation-rule 203
rule 1 /^.*/ /1925XXXXXX/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_BRI
translate calling 4
voice translation-profile SIP_01_OUT
translate calling 201
translate called 200
translate redirect-target 201
voice translation-profile SIP_02_OUT
translate calling 202
voice translation-profile SIP_03_OUT
translate calling 203
voice translation-profile SIP_DID_REDIRECT
translate called 199
voice translation-profile UC1
translate called 72
voice translation-profile UC1-Birmingham
translate called 70
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC520-8U-2BRI-K9 sn FCZ123013A3
archive
log config
  logging enable
  logging size 600
  hidekeys
username TAPAdmin privilege 15 secret 5 $1$FcB8$h0D9C3n8TTBBH/vC6TY7z1
ip tftp source-interface Vlan100
interface Loopback0
description $FW_INSIDE$
ip address 10.1.20.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.20.1 255.255.255.252
service-module ip default-gateway 10.1.20.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
switchport mode trunk
interface FastEthernet0/1/8
macro description cisco-switch
interface BRI0/1/0
no ip address
shutdown
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
trunk-group ALL_BRI 64
interface BRI0/1/1
no ip address
shutdown
interface BRI0/2/0
no ip address
shutdown
interface BRI0/2/1
no ip address
shutdown
interface Vlan1
ip address 192.168.0.248 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan100
ip address 10.1.1.2 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.254
ip route 10.1.20.1 255.255.255.255 Integrated-Service-Engine0/0
logging esm config
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 10.1.20.0 0.0.0.3
access-list 1 permit 192.168.161.0 0.0.0.255
access-list 1 permit 192.168.165.0 0.0.0.255
access-list 1 permit 192.168.164.0 0.0.0.255
access-list 1 permit 192.168.166.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.0.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.0.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.0.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip 192.168.165.0 0.0.0.255 any
access-list 103 permit ip 192.168.164.0 0.0.0.255 any
access-list 103 permit ip 192.168.166.0 0.0.0.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.0.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any log
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-8.bin alias spa525g-7-4-8.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/English_United_States/501-dictionary.xml alias English_United_States/501-dictionary.xml
tftp-server flash:/English_United_States/502-dictionary.xml alias English_United_States/502-dictionary.xml
tftp-server flash:/English_United_States/504-dictionary.xml alias English_United_States/504-dictionary.xml
tftp-server flash:/English_United_States/508-dictionary.xml alias English_United_States/508-dictionary.xml
tftp-server flash:/English_United_States/509-dictionary.xml alias English_United_States/509-dictionary.xml
tftp-server flash:/English_United_States/521-dictionary.xml alias English_United_States/521-dictionary.xml
tftp-server flash:/English_United_States/524-dictionary.xml alias English_United_States/524-dictionary.xml
tftp-server flash:/English_United_States/525G-dictionary.xml alias English_United_States/525G-dictionary.xml
tftp-server flash:/English_United_States/525G-kate.xml alias English_United_States/525G-kate.xml
tftp-server flash:/English_United_States/525G-tones.xml alias English_United_States/525G-tones.xml
tftp-server flash:/English_United_States/525G2-dictionary.xml alias English_United_States/525G2-dictionary.xml
tftp-server flash:/English_United_States/525G2-kate.xml alias English_United_States/525G2-kate.xml
tftp-server flash:/English_United_States/525G2-tones.xml alias English_United_States/525G2-tones.xml
tftp-server flash:/English_United_States/7921-dictionary.xml alias English_United_States/7921-dictionary.xml
tftp-server flash:/English_United_States/7921-font.dat alias English_United_States/7921-font.dat
tftp-server flash:/English_United_States/7921-kate.utf-8.xml alias English_United_States/7921-kate.utf-8.xml
tftp-server flash:/English_United_States/7921-kate.xml alias English_United_States/7921-kate.xml
tftp-server flash:/English_United_States/7960-tones.xml alias English_United_States/7960-tones.xml
tftp-server flash:/English_United_States/be-sccp.jar alias English_United_States/be-sccp.jar
tftp-server flash:/English_United_States/CME-locale-en_US-English-8.1.2.1.tar.cfg alias English_United_States/CME-locale-en_US-English-8.1.2.1.tar.cfg
tftp-server flash:/English_United_States/g3-tones.xml alias English_United_States/g3-tones.xml
tftp-server flash:/English_United_States/gp-sccp.jar alias English_United_States/gp-sccp.jar
tftp-server flash:/English_United_States/ipc-sccp.jar alias English_United_States/ipc-sccp.jar
tftp-server flash:/English_United_States/mk-sccp.jar alias English_United_States/mk-sccp.jar
tftp-server flash:/English_United_States/rp-sccp.jar alias English_United_States/rp-sccp.jar
tftp-server flash:/English_United_States/tags_file alias English_United_States/tags_file
tftp-server flash:/English_United_States/tc-sccp.jar alias English_United_States/tc-sccp.jar
tftp-server flash:/English_United_States/td-sccp.jar alias English_United_States/td-sccp.jar
tftp-server flash:/English_United_States/utf8_tags_file alias English_United_States/utf8_tags_file
tftp-server flash:/phones/7906_7911/apps11.8-5-4TH1-6.sbn alias apps11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-4TH1-6.sbn alias cnu11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-4TH1-6.sbn alias cvm11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-4TH1-6.sbn alias dsp11.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-4TH1-6.sbn alias jar11sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-4S.loads alias SCCP11.8-5-4S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
cptone GB
shutdown
caller-id enable
voice-port 0/0/1
cptone GB
shutdown
caller-id enable
voice-port 0/0/2
cptone GB
shutdown
caller-id enable
voice-port 0/0/3
cptone GB
shutdown
caller-id enable
voice-port 0/1/0
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/2/0
cptone GB
voice-port 0/2/1
cptone GB
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan100
sccp ccm 10.1.1.2 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description catch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
direct-inward-dial
port 0/1/0
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
dial-peer voice 100 pots
direct-inward-dial
port 0/2/0
dial-peer voice 101 pots
direct-inward-dial
port 0/2/1
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 555
b2bua
session protocol sipv2
session target ipv4:10.1.20.1
voice-class sip outbound-proxy ipv4:10.1.20.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
description **CCA*UK*Special Services <5ppm**
translation-profile outgoing SIP_01_OUT
preference 3
destination-pattern *010843.......
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
description **CCA*UK*National Geographic - <= 10 digits**
preference 3
destination-pattern *0101.......T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 202 voip
description **CCA*UK*Voicetext Services**
preference 3
destination-pattern *01180..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 203 voip
description **CCA*UK*National Geographic - 11 digits**
preference 3
destination-pattern *010[123].........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 204 voip
description **CCA*UK*Location independent & Corporate**
preference 3
destination-pattern *0105[56]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 205 voip
description **CCA*UK*Internet Access**
preference 3
destination-pattern *010844.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 206 voip
description **CCA*UK*Local Rate NGN - 11 digit**
preference 3
destination-pattern *010845.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 207 voip
description **CCA*UK*Free Numbers - <= 10 digits**
preference 3
destination-pattern *010800....T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 208 voip
description **CCA*UK*local direct dial - 4/5 digits**
preference 3
destination-pattern *01[2-9]...T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 209 voip
description **CCA*UK*Int Operator / Blind Directory**
preference 3
destination-pattern *011[59]5
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
description **CCA*UK*Level1 Services**
preference 3
destination-pattern *0115[0-4]T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 211 voip
description **CCA*UK*International Toll Free**
preference 3
destination-pattern *0100800T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 212 voip
description **CCA*UK*Non-Emergency Police Service**
preference 3
destination-pattern *01101
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 213 voip
description **CCA*UK*Personal & Radio Paging**
preference 3
destination-pattern *0107[06]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 214 voip
description **CCA*UK*Free Numbers - 11 digit**
preference 3
destination-pattern *01080[08].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 215 voip
description **CCA*UK*Free Numbers - 10 digit**
preference 3
destination-pattern *010500......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 216 voip
description **CCA*UK*Speaking Clock**
preference 3
destination-pattern *01123
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 217 voip
description **CCA*UK*Local Rate NGN - <= 10 digits**
preference 3
destination-pattern *010845T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 218 voip
description **CCA*UK*Services of Social Value**
preference 3
destination-pattern *01116...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 219 voip
description **CCA*UK*Special Services <10ppm**
preference 3
destination-pattern *01087[123].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 220 voip
description **CCA*UK*National Non Geo - 11 digits**
preference 3
destination-pattern *010870.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 221 voip
description **CCA*UK*Directory Enquires**
preference 3
destination-pattern *01118...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 222 voip
description **CCA*UK*local direct dial - Set to 6 or 8 digits**
preference 3
destination-pattern *01[2-9].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 223 voip
description **CCA*UK*Mobile**
preference 3
destination-pattern *0107[1-5,7-9]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 224 voip
description **CCA*UK*Operator**
preference 3
destination-pattern *01100
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5100 voip
description **Gamma Telecom SIP Trunk**
destination-pattern 88...
session target ipv4:83.245.6.81
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 199 voip
description **SIP trunk incoming dial-peer**
translation-profile incoming SIP_DID_REDIRECT
voice-class codec 1
no vad
dial-peer voice 71000 voip
destination-pattern 2..
session target ipv4:192.168.0.253
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 72000 voip
translation-profile incoming UC1
incoming called-number 72...
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 250 voip
translation-profile outgoing SIP_02_OUT
preference 3
destination-pattern *020843.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 251 voip
preference 3
destination-pattern *0201.......T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 252 voip
preference 3
destination-pattern *02180..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 253 voip
preference 3
destination-pattern *020[123].........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 254 voip
preference 3
destination-pattern *0205[56]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 255 voip
preference 3
destination-pattern *020844.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 256 voip
preference 3
destination-pattern *020845.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 257 voip
preference 3
destination-pattern *020800....T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 258 voip
preference 3
destination-pattern *02[2-9]...T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 259 voip
preference 3
destination-pattern *021[59]5
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 260 voip
preference 3
destination-pattern *0215[0-4]T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 261 voip
preference 3
destination-pattern *0200800T
voice-class codec 1
dtmf-relay sip-notify
no vad
dial-peer voice 262 voip
preference 3
destination-pattern *02101
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 263 voip
preference 3
destination-pattern *0207[06]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 264 voip
preference 3
destination-pattern *02080[08].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 265 voip
preference 3
destination-pattern *020500......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 266 voip
preference 3
destination-pattern *02123
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 267 voip
preference 3
destination-pattern *020845T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 268 voip
preference 3
destination-pattern *02116...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 269 voip
preference 3
destination-pattern *02087[123].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 270 voip
preference 3
destination-pattern *020870.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 271 voip
preference 3
destination-pattern *02118...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 272 voip
preference 3
destination-pattern *02[2-9].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 273 voip
preference 3
destination-pattern *0207[1-5,7-9]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 274 voip
preference 3
destination-pattern *02100
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3009 pots
description ChrisSampson
translation-profile incoming ChrisSampson_Called_15
incoming called-number 004984
direct-inward-dial
dial-peer voice 3011 pots
description CamdenFWD
translation-profile incoming CamdenFWD_Called_17
incoming called-number 004986
direct-inward-dial
dial-peer voice 300 voip
translation-profile outgoing SIP_03_OUT
preference 3
destination-pattern *030843.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 301 voip
preference 3
destination-pattern *0301.......T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 302 voip
preference 3
destination-pattern *03180..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 303 voip
preference 3
destination-pattern *030[123].........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 304 voip
preference 3
destination-pattern *0305[56]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 305 voip
preference 3
destination-pattern *030844.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 306 voip
preference 3
destination-pattern *030845.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 307 voip
preference 3
destination-pattern *030800....T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 308 voip
preference 3
destination-pattern *03[2-9]...T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 309 voip
preference 3
destination-pattern *031[59]5
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 310 voip
preference 3
destination-pattern *0315[0-4]T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 311 voip
preference 3
destination-pattern *0300800T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 312 voip
preference 3
destination-pattern *03101
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 313 voip
preference 3
destination-pattern *0307[06]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 314 voip
preference 3
destination-pattern *03080[08].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 315 voip
preference 3
destination-pattern *030500......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 316 voip
preference 3
destination-pattern *03123
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 317 voip
preference 3
destination-pattern *030845T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 318 voip
preference 3
destination-pattern *03116...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 319 voip
preference 3
destination-pattern *03087[123].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 320 voip
preference 3
destination-pattern *030870.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 321 voip
preference 3
destination-pattern *03118...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 322 voip
preference 3
destination-pattern *03[2-9].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 323 voip
preference 3
destination-pattern *0307[1-5,7-9]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 324 voip
preference 3
destination-pattern *03100
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 87 voip
description **CCA*UK*Emergency VoiceText**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 98000
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 88 voip
description **CCA*UK*Emergency**
preference 3
destination-pattern 999
dial-peer voice 78 voip
preference 3
shutdown
dial-peer voice 81 voip
preference 3
destination-pattern 918000
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 82 voip
preference 3
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 69 voip
preference 3
destination-pattern 90843.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 70 voip
preference 3
destination-pattern 901.......T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 67 voip
preference 3
destination-pattern 9180..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 56 voip
preference 3
destination-pattern 90[123].........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 66 voip
preference 3
destination-pattern 905[56]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 68 voip
preference 3
destination-pattern 90844.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 71 voip
preference 3
destination-pattern 90845.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 62 voip
preference 3
destination-pattern 90800....T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 83 voip
preference 3
destination-pattern 9112
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 79 voip
preference 3
destination-pattern 9[2-9]...T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 61 voip
preference 3
destination-pattern 912
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 85 voip
preference 3
destination-pattern 91[59]5
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 58 voip
preference 3
destination-pattern 915[0-4]T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 65 voip
preference 3
destination-pattern 9999
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 77 voip
preference 3
destination-pattern 900800T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 55 voip
preference 3
destination-pattern 9101
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 59 voip
preference 3
destination-pattern 907[06]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 75 voip
preference 3
destination-pattern 9080[08].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 52 voip
preference 3
destination-pattern 90500......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 53 voip
preference 3
destination-pattern 9123
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 64 voip
preference 3
destination-pattern 90845T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 63 voip
preference 3
destination-pattern 9116...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 73 voip
preference 3
destination-pattern 9087[123].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 76 voip
preference 3
destination-pattern 90870.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 72 voip
preference 3
destination-pattern 9118...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 74 voip
preference 3
destination-pattern 9[2-9].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 57 voip
preference 3
destination-pattern 907[1-5,7-9]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 60 voip
preference 3
destination-pattern 9100
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 54 voip
description **CCA*UK*0871 271 1100**
preference 3
destination-pattern 908712711100
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 80 voip
preference 4
voice-class codec 1
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
keepalive target ipv4:83.245.6.81
retry invite 2
retry register 10
timers connect 100
sip-server ipv4:83.245.6.81:5060
connection-reuse
host-registrar
telephony-service
video
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 192.168.0.248 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message TeacherActive 2
url services http://10.1.20.1/voiceview/common/login.do
url authentication http://10.1.20.2/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale U4 load CME-locale-en_GB-English-8.1.2.1.tar
network-locale U4
load 7906 SCCP11.8-5-4S
load 7911 SCCP11.8-5-4S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-8
load 525G2 spa525g-7-4-8
time-zone 5
date-format dd-mm-yy
keepalive 30 auxiliary 4
voicemail 555
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
url services 1 http://10.1.20.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2. Sun Apr 29 14:00:04 BST 2012^^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
ntp server 158.43.128.33
end
Looks like the phones are not sending the *. Is this happening with all of the phone models?
You can try doing a "csim start *01" just to make sure that UC is processing the "*" as a digit.
-Luis A.
I've done that already and it's fine,  I've even done added a forward to the inbound calls under Translation-Rule 199 forwarding the inbound calls to my mobile using *01, *02 or *03 and it redirects out to my phone with the correct CLID.
All of the phones when on the 2nd system have this problem, when I set my phone back to the 1st system the * keypresses working without any problems.
Something that did occur to me though,  when I press **1 it initiates a 'Call-Forward' from my phone so it's deffo picking it up but not for making a call - - -  could it be that it's ignoring the *'s because the UC wants to use them for access codes...... just a thought?
