UC520 Registration to gatekeeper
Has anyone tried to register a UC520 to Gatekeeper? I'm having trouble getting the UC520 to register. Below are may gateway and gatekeeper configs and the debug h225 asn1 from the gateway.
Gateway
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
h225 listen-port 1820
no call service stop
sip
bind control source-interface Vlan20
bind media source-interface Vlan20
registrar server expires max 600 min 60
interface Vlan20
description voice
ip address 172.21.2.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip id ZONE-CME ipaddr 172.21.1.4 1719
h323-gateway voip h323-id GW-CME
h323-gateway voip tech-prefix 8
gateway
dial-peer voice 2100 voip
destination-pattern 7...
session target ras
Gatekeepter
gatekeeper
zone local Gatekeeper msi-uclab-local
zone subnet Gatekeeper 172.21.2.0/24 enable
zone prefix Gatekeeper 4... gw-priority 5 GW-CME
zone prefix Gatekeeper 7... gw-priority 5 gk-trunk_1
no shutdown
littlesalt2811(config)#do debu ras
H.323 RAS Messages debugging is on
Sep 29 12:18:49.971: RecvUDP_IPSockData successfully rcvd message of length 70 from 172.21.2.1:59522
Sep 29 12:18:49.975: GRQ (seq# 2212) rcvd
Sep 29 12:18:49.975: IPSOCK_RAS_sendto: msg length 12 from 172.21.1.4:1719 to 172.21.2.1: 59522
Sep 29 12:18:49.975: RASLib::RASSendGRJ: GRJ (seq# 2212) sent to 172.21.2.1
littlesaltUC520#show gateway
H.323 ITU-T Version: 4.0 H323 Stack Version: 0.1
H.323 service is up
Gateway GW-CME is not registered to any gatekeeper
Alias list (CLI configured)
H323-ID GW-CME
E164-ID 3001
Alias list (last RCF) is empty
littlesaltUC520#debug h225 asn1
H.225 ASN1 Messages debugging is on
littlesaltUC520#
littlesaltUC520#term mon
littlesaltUC520#
Sep 29 18:17:54.654: RAS OUTGOING PDU ::=
value RasMessage ::= gatekeeperRequest :
requestSeqNum 2215
protocolIdentifier { 0 0 8 2250 0 4 }
rasAddress ipAddress :
ip 'AC150201'H
port 59522
endpointType
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
prefix dialedDigits : "8"
mc FALSE
undefinedNode FALSE
gatekeeperIdentifier {"ZONE-CME"}
endpointAlias
h323-ID : {"GW-CME"},
dialedDigits : "3001"
Sep 29 18:17:54.654: RAS OUTGOING ENCODE BUFFER::= 00A008A6060008914A000400AC150201E8822800B500001240013C0504010000B00380005A004F004E0045002D0043004D004502400500470057002D0043004D004501806334
Sep 29 18:17:54.658: RAS INCOMING ENCODE BUFFER::= 080008A6060008914A000420
Sep 29 18:17:54.658: RAS INCOMING PDU ::=
value RasMessage ::= gatekeeperReject :
requestSeqNum 2215
rejectReason terminalExcluded : NULL
Hall of Fame Super Gold
Re: UC520 Registration to gatekeeper
You should check on the GK why it rejects the GW.
Can you recommend what debug I should run. I'm doing a debug RAS but that isn't giving me enough to go off of.
Sorry, I am not familiar with GK debugs. Hope you can find something there.
Hi, you have a reason for reject(the last line of your debug)
Try to watch here:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a008011221e.shtml#rr2
I found this cisco web-page very useful watching for debug commands(Voice Debug Lookup section): http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080207ec6.shtml
364
