Community Member
UC520 SIP Trunk not registering
I have a UC520, and I have been trying to figure out why my SIP trunk is not registering. When I looked at the debugs, I noticed that FROM address is '101' - which is the Auto Attendant extension, which is not accepted by my SIP provider. It really should be the 'username' assigned to me. How do I get it changed so I could register?
Thanks.
Nov 16 05:22:22.998: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sipgw.voicenetwork.ca:5060 SIP/2.0
Via: SIP/2.0/UDP <IP ADDRESS>:5060;branch=z9hG4bKC6EF1
From: <sip:101@sipgw.voicenetwork.ca>;tag=168ABD8-226
To: <sip:101@sipgw.voicenetwork.ca>
Date: Sun, 16 Nov 2008 05:22:22 GMT
Call-ID: 13DC0899-B2BA11DD-8071FAEB-FB513C66
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1226812942
CSeq: 133 REGISTER
Contact: <sip:101@<SOURCE IP ADDRESS>:5060>
Expires: 3600
Authorization: Digest username="XXXXX",realm="voicenetwork.ca",uri="sip:sipgw.voicenetwork.ca:5060",response="656a283e5cda0e70d74cfc716302a5e3",nonce="491faf15164f3659ade40ccc97a77c62701408c7",algorithm=md5
Content-Length: 0
Silver
Re: UC520 SIP Trunk not registering
What is the CCM/CME version you are using?
Send the "show tech" output from UC520 and the output of the "show sip-ua" command.
Output of "debug ccsip all" and "debug voip ccapi inout"
Community Member
Hi, I was able to get it figured out!
Though now I have a different problem, that I will repost.
Thanks.
Community Member
How did you stop the AA number being used in the SIP trunk?
247
